Farmstead planning
   / Farmstead planning #21
Despite being in tornado alley, most of Texas does not seem to do basements...
They just ran county water up our road...animals sound like a good excuse to stay home.
   / Farmstead planning #22
When I built our place here in 2006.....................
Also what was well worth a little extra money was pocket doors - in a smaller house like ours (1700 sf) they really give you much more useable space and I made all of mine 36" as well - no problems using a walker or wheelchair in the future if necessary and easy to open/close doors.
Your second paragraph reflects our house we built in 2018/2019. Plus our shower has no thresold to step over. Shower head pointed away from entry side. Plus our stairway to the walkout basement is 4ft wide to accomodate a future stair chair to basement if needed. Jon
   / Farmstead planning #23
Yes. I have a master plan that shows where all the buildings go, the driveway, orchard, garden, etc. Everything I can think of. I also made a model of the house and put it out in the yard to check for sun orientation to be sure the overhangs were enough and sun angles were what I wanted.
But that doesn't mean I don't change things as I go along.
Can we get a sketch of your lay out? It would greatly help us to give opinions. And do you know the prevailing winds? Put it into this sketch with compass direction. I'm sure all your ideas are good, but you asked. A review, is what you take from it, and all suggested ideas are mostly good ideas from people that have been there, done that.. etc. I've learned a great deal from this site, of what works and what doesn't. The more info you give the better the suggestions get. Wish the internet had been around when I built my house. Solar is a big thing to consider, if you have a nice straight roof line faceing south to hold it. Doing your own remote panels on stands, in your own system with net metering, is a waste of time and money. Which happened to me in a recent, one hundred year event, ice storm. The cost to rebuild it, took all the benefits out. Just say'en.
   / Farmstead planning #25
If you require a septic, well, etc. anything that's buried, please, please take and record measurements to it from two fixed points, like two corners of your house or barn, for example. In 20 years you'll appreciate it.
That is a great idea. I did that when we replaced and relocated our old septic tank. I also put a metal plate over the hatch - buried down a bit - so I could locate it with a metal detector if necessary. I made a nice map of the two key points and the measurements. Then I lost the file. So, I guess having a back up plan with the metal plate will save me.
   / Farmstead planning #26
I keep everything like that in my red binder. Along with a lot of other pertinent stuff for this property.
   / Farmstead planning #27
Now that is a spectacular idea - creating a single binder/folder to store the information related to the buildings & property.
Being the (at a minimum) third owner of my current home/property I wish I had the information about where the septic, water, propane, and electric lines are routed. While some have been relatively easy to get an idea where the main lines are all the branches/offshoots have made it o_O
As it currently lies with my house being separated from a larger single property there are water and electric lines that cross from my property to the property it was once part of - which is currently owned by the couple who divided it and sold the house and some acreage to me. However, they are also not the first/original home/property owners either. So while I think we've managed to separate the utility lines enough to avoid increasing each other's utility bills it'd be nice to know where those lines are located in order to efficiently terminate them underground on our respective properties (rather than at the surface on each other's properties)......
   / Farmstead planning #28
Yes. Take photos of everything before you dry wall with references of where the pic was taken. Print these out. I did this, and Oh my Gosh! was this helpful, 20 years later, when we later wanted to add stuff to the walls. You can see exactly where the DWV and electrical and water lines went.
   / Farmstead planning #29
All the access points on my well and septic system come to the surface with risers and weather-proof caps. However - I still took and recorded triangulated measurements to each.
Heaven forbid I should ever have to find any of these points under feet of snow.
   / Farmstead planning #30
Really? You guys actually plan all this stuff? I must not be old enough yet 😂
Planning yes, but my Doing has slacked a bit ... mostly as Budget permits, in my case.
2008 CATERPILLAR 304C CR EXCAVATOR (A51406)
2008 CATERPILLAR...
2015 FORD F-250XL SUPER DUTY TRUCK (A51406)
2015 FORD F-250XL...
STORAGE FEES (A52141)
2019 VOLVO VNL HIGH ROOF SLEEPER (A50046)
2019 VOLVO VNL...
2019 JOHN DEERE 843L-II FELLER BUNCHER (A51242)
2019 JOHN DEERE...
NEW Woods Reverse Rotation 5ft Tiller (A52128)
NEW Woods Reverse...
