farmall 504 loader issues
   / farmall 504 loader issues #1
bobs Uruncle
branson2400h
Hey everyone - I picked up an old farmall 504 d awhile back. Loader is very slow to lift. There was a lot of water in the hydraulic fluid. Replaced fluid and filter and it did not help. From what I understand there is a oring on the pipe between the pump and filter which could cause hydraulic issues. Also, there are different size pumps that came on these tractors. Wondering if the pump is just not big enough. Not sure if it's always been this way or something new. It was that way when I bought it. The pumps are internal around the bellhousing area. Not a front mounted pump. Anyone have any experience with these?
thanks
   / farmall 504 loader issues #2
I've got no Farmall experience. I do know if the three point is in the full up position it can go into bypass mode and really slow all other hydraulic functions. This usually indicates an adjustment on the rock shaft is required.
interesting= I will try that thanks.
International 1086 2WD Tractor (A49251)
International 1086...
Yetter 3415 Rotary Hoe (A49251)
Yetter 3415 Rotary...
2001 Sterling L7500 Dump Truck (A48081)
2001 Sterling...
2017 ISUZU NPR/NPR-HD (A46683)
2017 ISUZU...
2025 Single Cylinder 40in Grapple Rake Skid Steer Attachment (A46683)
2025 Single...
2014 VOLVO VN SERIES DAY CAB (A48992)
2014 VOLVO VN...
