68 JD 400 hydraulics acting up.HELP!
/ 68 JD 400 hydraulics acting up.HELP!
Well I had both filters off again and placed the gasket in the housing and bolted the caps back on and no leaks. So I proceeded to fill the transmission to the full line on the stick cycling the different hydraulics as I checked it and everything worked better and the tractor moved in gear with little to no hesitation so it looks like the cleaning of the screen and changing the filters fixed the problem. However just as I finished bolting the step/ grate back on I noticed that now there was a dripping of fluid from the backhoe filter housing. Not as bad as the first time and it didn’t start leaking until a solid half hour or more after it was running but leaking non the less. The transmission filter was dry as a bone but the hoe filter leaked again. I guess I will have to try again tomorrow and keep my fingers crossed that the third time is the charm.
Filters, taken off and re- installed, this time no leaks and all hydraulics seem to working properly with little to no delay in forward or reverse engagement. Cleaning the screen and changing the filters seems to have corrected the issues.
/ 68 JD 400 hydraulics acting up.HELP! #23
Congratulations on your successful repair. Thank you for posting your results. Only a small % of this forum members find the time or necessity to post their repair results.
Ford 8210 (A60462)
Ford 8210 (A60462)
LANDHONOR PF-11-3500G-48" PALLET FORKS (A60430)
LANDHONOR...
Year: 2017 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 101,691 Plate: Body Type... (A55853)
Year: 2017 Make...
2019 Dodge Grand Caravan Van (A59231)
2019 Dodge Grand...
2019 Krause 8005-30 Excelerator - High Speed Vertical Tillage - 30 FT Working Width (A61307)
2019 Krause...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
