Farm UTV/RTV Purchase
/ Farm UTV/RTV Purchase #61
where did you source that windshield ?
Canton Powersports in Canton, TX. They installed the AudioFormz roof and windshield at the same time. It clips on the rollcage. The lower part folds up so you can open the front compartment.
/ Farm UTV/RTV Purchase #62
My biggest complaints on my Honda 1000-5 were that the roll cage covered the entire bed which made it harder to load and unload stuff. Also when it's hard to keep a slow and steady speed, and when you are putting around the heat from engine under the seat gets uncomfortable. The seats in the back are not comfy and when they're up you have zero bed space. Had tons of power though!
None of your complaints I had any issues with. I installed floor mat material under the front seat that keeps the heat down. We rarely use the back seats and when we do the kids know not to complain. ;)
I usually have back seats down but getting them up is at most about 60 seconds.
If you need slow and steady speed I would put it in manual mode.
/ Farm UTV/RTV Purchase #63
I installed two 4" bilge fans under the seat to try and direct the air down and back. It definitely helped!
I did use the manual mode quite a bit but when you're doing something like spraying and need to keep a constant 3-4 mph it was difficult to accomplish.
It was a nice machine, just didn't suit my needs as well as the Mule does.
/ Farm UTV/RTV Purchase #64
I have a Bobcat diesel that I got a great deal on- it is no speed demon ( tops out at 25mph iirc). My property is quite hilly. I’ve never really noted a significant drop in speed when climbing any of my ‘roads’ in high when not carrying a sizable load in the bed.
I use mine for work on the property not for ‘fun’- (that’s what the quads are for) so the speed I can travel is not critical-realistically I wouldn’t ( and very often don’t) travel at anywhere near top speed of the Bobcat on any of my roads/trails.
/ Farm UTV/RTV Purchase #65
Do some research. Battery powered golf cart batteries last about 6 years and are not cheap to replace. I do not know what UTV's are using for batteries.
We looked at an electric golf cart before buying the Mule and a decent one was $5k with no warranty. The Mule was $8.2k with a three year warranty.
My Hisun is 5 years old and will likely need new batteries sometime in the future if I plan on maintaining the supposed 45 mile range, which I never come close to using. I seldom drive more than 10 miles in a day, and I think the batteries may last quite a while. I did price new batteries. They come in all sorts of different types and prices with varying attributes, none of which are really that important to me. The unit has the capability to utilize every different type of battery. The dealer recommends replacing them with standard lead acid batteries, the least expensive option, which would cost around $1,000. If you consider overall cost, new vehicle plus battery replacement 6 or whatever many years down the road, it still quite favorably compares to a gas rig of relatively similar capability. But without the upkeep. Hisun has a 2 year warrantee, but not much to go wrong on an electric rig.
/ Farm UTV/RTV Purchase #66
I have a Kawasaki Mule Pro FXT that I'm very pleased with on my hilly 300 acres in W. Tennessee. It'll hold 6 adults - it's intimate but can be done. The back seat folds up to increase the bed size and the bed dumps easily. I think it's one of if not the quietest machine in this class. We can have conversations while driving more easily than on my friends' Polaris and Can Am machines. It has more speed than I need - rated into the 40's but I've never needed to move that fast in it. I had the Dealer add a hard top, windshield, and winch to mine. Some models come with them but mine didn't.
/ Farm UTV/RTV Purchase #67
I lucked out and bought the type of UTV that I really needed. I had a Kubota RTV900 and it was the perfect work machine for me. I used it hauling chainsaws, firewood, dirt, etc and the hydraulic dump bed never had a problem lifting what ever I put in it. I would help the neighbor move full hay wagons around with ease. It did slow heavy work perfectly and with power steering, it was effortlessly.
Everyone's needs are different so the real task for the OP is to understand his real needs will be. Will he need good suspension, speed, carry capacity, whatever.....buy the right one for your needs.
/ Farm UTV/RTV Purchase #68
That was my big complaint with the full cab Can Am and Polaris 1000's.....I thought my RTV-X1100C was loud in the cab....until I rode one of those. Between the heat and the noise I don't wanna sit in one of those all day.
/ Farm UTV/RTV Purchase #69
I have a 40 acre hobby farm, bushlot, that I maintain with a 2008 Kubota Bx2660 tractor and a 2016 Kubota RTV x1100c ... I smile when some snicker about the slow speed of the Kubota RTV models, but quite frankly I never get it up to 25 mph on my property and I doubt I could if I owned any side by side or truck. But boy do I like having a hydraulic dump bed that holds three tractor buckets, of gravel or soil (or hay up to the roof) ....or hydrostatic trannie that slows me with out needing brakes used. Or a winter warm cab or summer AC cool cab. .....so look at your needs carefully, how many times will you hsve 4 people to decide seating, ( my grand kids sit in the box many times and have a riot) Decide whether you will need a heavy capable lift box , and yes will you ever need to go over 25 mph on your property. How.much parking room or trail width do you need. A Kubota only needs 60 in wide trails. Eg ....A pickup will need much more . Do you want gas engine or a economical sipping tough diesel 3 cyl. ....Many things to prioritize....good luck
/ Farm UTV/RTV Purchase #70
When faced with similar back in 1997 I picked up Suzuki Samurai with 5spd for the grand sum $1025
24 years later I can say I would do again in heartbeat...
It was cheap because of a loud transmission which turned out to be a bad bearing... the kit was $80 plus while in replaced the clutch disk...
I know several people that did the same thing.
All good points... food for thought. Thank you for much.
/ Farm UTV/RTV Purchase #72
I learned that I really wanted a side by side when my boarder loaned me her Mule 2 seater with a manual dump bed last winter.
At first, my husband was all "don't need it", then he watched me using it, driving it into the barn, cleaning stalls into it, drive to manure pile, back up better, dump with ease, go out at 11pm to give more hay...I back up to the loft door, drop a few bales into the bed, drive it out to the horses, take blankets back and forth, run out to check the water. All things that I stopped asking for help with. After a couple of week, he said "I've changed my mind, I think you do need something like this".
I did not like the fumes or noise. I went and looked at new Mule, I could have bought the neighbor's, but decided EV was the way for me. I have the Polaris Ranger EV on order. Paid my deposit...was given a ridiculously long window for when it will ship. Dec. 15-Jan 26, 2022. It was "they should be shipping in November" when I put down a deposit. At least I locked in the pre-$1200 increase price. Next up is getting an outlet installed next to the likely parking area under the awning on the barn.
I'm a little sad that it is bucket seats, not a bench seat, but I really wanted that EV, and not made in China, I like that the Polaris are made in the USA still. Even if some of the parts are not...
I find the kids that come to the farm LOVE riding in the bed. Top speed is not one of my concerns.
/ Farm UTV/RTV Purchase #73
Perhaps some of you very wise farmers out there can direct me to determining what UTV/RTV to purchase for my new farm. It will need to have 4 seats (Family) and a lift bed. Kubota is an interesting one. Any help would be appreciated. A couple of things. Farm is 22 acres of pasture, few trees in North Texas. Plan to have cattle, orchard, vegetable and berry farm.
We had one of Kubota's 900 series. Loved it. We looked at Polaris, etc. and the one thing that tipped us for Kubota was the dump bed. All the others had power assist but my wife was not strong enough to easily close them. Kubota has hydraulic up and down. You can dump it from the cab - and if it will matter, your wife will easily be able to do it. My wife considered the Kubota hers. She would let me drive it but it was her baby.
/ Farm UTV/RTV Purchase #74
I have the Kawasaki Pro Fxt and love it. It has the 4 doors and the bed can convert to a bed that will fit a pallet. It takes less than 2 minutes to convert it. Love the power of the machine
/ Farm UTV/RTV Purchase #75
I am a little late for this thread, but I have an Intimidator UTV, which is also marketed by Mahindra under their nameplate. I have the "crew" model, which seats 6 people who don't mind being really close! I chose it because it had the heftiest axles and brakes on the market at the time I bought it (about 2012) and the highest towing capacity (2000 lb) and the highest dump bed capacity ( 1000 lb) and a lot of suspension travel (11") for a work-type UTV (as opposed to the Polaris type, which is more geared for recreational uses). By today's standards, it is slow (max speed 33 mph) and not that powerful (25 Hp), but I don't need to go that fast on our Ohio hills. I probably drive 10-15 mph max when off road. My only beef with it is that they put the battery under the dump bed, which means you cannot get at the battery if it is dead, as the dump bed has an electric lift. I have since had the battery moved under the hood.
/ Farm UTV/RTV Purchase #76
Make sure your dump bed is power operated. I have Polaris Ranger with a manual lift. I can’t dump a partial load, as in spreading gravel. Once it’s lifted, gravity takes over it all will come out. Then you get the shovels.
/ Farm UTV/RTV Purchase #77
Like some of the others, I love my 2015(?) Polaris Ranger 570 full size ... I wish that all my other equipment was as dependable as the Ranger. It's used pretty much every day ... most days it's pulling an 8-bay dog trailer around our 86 acre farm. I got the front windshield and back glass to keep the dust out of the cab. I haven't had any issues with the belt (or anything else for that matter).
A buddy bought a Honda Pioneer and couldn't stand all the rattling, so he sold it and bought a Ranger.
I'm sure the others are fine, but if I have a reason to buy another UTV, it'll be another Ranger.
/ Farm UTV/RTV Purchase #78
Kubota Rtv1140 is the best farm purchase I’ve made. Never have had a problem climbing hills. Have had the power to tow a half full fuel truck with a dead battery out of a field. Hydraulic dump bed is a godsend. Make sure you get the front winch. I like that the top speed is about 22 mph. Means the kids don’t abuse it.
/ Farm UTV/RTV Purchase #80
I am in Texas as well. I opted to go with Kioti since I love my tractor and the dealer always takes care of me. Not to mention Kioti actually had a decent inventory. I bought a K9 2440. It goes up to 31mph and has a large dump bed. Definitely not the best turning radius though since it’s so long. The K9 series comes with some extra features such as doors and sprayed bed liner. Kioti also makes a Mechron series if you’re looking for something more basic.
7'x16' Enclosed Trailer (A64127)
7'x16' Enclosed...
2012 Kenworth T800 (A64127)
2012 Kenworth T800...
2005 Mack CL713 Truck (A60352)
2005 Mack CL713...
John Deere 12in Channel Bucket w/ Teeth Excavator Attachment (A64194)
John Deere 12in...
3pt 14' 15 Shank Chisel Plow (A64127)
3pt 14' 15 Shank...
Case IH 315 Magnum (A62177)
Case IH 315 Magnum...
