F3680 slope capacity?
/ F3680 slope capacity? #21
If you get the F-3680 I would just mow over it several times at good height to chop it into finer bits and leave it where is. (Always mow at full throttle.) The F machines are industrial-rugged, but not so easy to change cutting height often. (do not need tools, just fiddly!) I settled on about 4" for everything all year and just call it 'Mowed Paddock'.... works fine here for us! Even set my JD 22" SP mower the same for around-house edging and trim. Cheers, Rip
Is the PTO output connection on the F-3680 the same as on a regular Kubota tractor like the L2501? I'm guessing the lift mechanism isn't the same as a tractor 3pt so there wouldn't be an easy way to use a light duty rotary brush cutter designed for a tractor on the F-3680?
/ F3680 slope capacity? #23
Hello Rocks, It is similar but Not the same! The F lift system is basically a 3pt (mounted bit lower to ground) without the top link. I have set up several custom attachments to use just the lift arms & pins (cat 1) with the rear arm mounts so lifts at same angle and arc as the arms move, without the toplink to provide a parallelogram action. Not great, but OK for what I do.
The other bigger issue is PTO Speed.... the F is full engine RPM (about 2800) while a regular utility (or CUT) is 540. Have not paid attention to direction, which could be another problem.
The F is primarily a mower.... and what I mainly use it for.... the other bits I have fabricated give it additional versatility, but do not turn it into a regular tractor.... but you already have such for those duties. A number of companies do make flail mower heads which mount right up for these machines if you expected to have ongoing need for such. They not a mulcher, but can handle very rough stuff on regular basis. I would classify the standard Kubota RCK rotary mower decks halfway between a 'finish' mower and a 'brush hog or slasher'.
Our place was Very Overgrown when we bought it and I did consider such a head, but took my time and got it all mowed fence-to-fence with the Kubota 60" deck.... bit of time but no dramas .... and even with only single drive belt (vs the double it supposed to have)! And it was ROUGH!!
Good Luck!! Cheers, Rip
Thank you. I had no idea that the PTO speed was like that or that the direction of rotation could be another issue.
/ F3680 slope capacity? #25
I think most mid-mount rotary CUT or Utility mower deck PTOs run at similar speeds.
/ F3680 slope capacity? #26
Your Kubota F-3680 model PTO output shaft should be the same as for example IH Farmall Cub tractor PTO shaft is - it's easy to count the splines & measure the OD if it is .098" ?
See my post couple of years ago regarding my F3060
Kubota F3060 PTO Shaft - OEM Replacment No Longer Available!
(The U-joints in F-3680 PTO shaft may or may not be the same as MOOG 861 ?)
Weasler parts are readily available - I hope this helps.
Cheers
/ F3680 slope capacity? #27
PTO output on F-3680 is smaller spline shaft than 'standard rear PTO on other Utility, CUT or SCUT tractors of any make I know of and is used across many models and years of Kubota F, Z and other mowers.
It may well be same as under-belly PTO used for some shaft-drive mid-mount mower decks and front-mount snowblowers. The several custom fabricated attachments I have made are non-power.
A Happier New Year to All!! Cheers, Rip
/ F3680 slope capacity? #28
I have 5-6 acres of hillside some with 25 degree slopes to mow. Local kubota dealer has a 2012 F3680 4wd with 2300 hours for $9,000 …
Wondering if this is something that would work or should I put that money towards a Ventrac or Power Trac instead?
What did you end up going with to keep this bank mowed ?
Power trac pt1445 but am still in the break in period so I don’t quite have an opinion if it was the right choice for these slopes. Already had to upgrade the Oem wheels on the mower deck and fabricate a debris deflector. But not enough hours to have a real opinion yet.
/ F3680 slope capacity? #30
Wow, that is an impressive looking tractor!
Just got this from the manufacturer's website:
/ F3680 slope capacity? #31
/ F3680 slope capacity? #32
Oh mannnn, you thinking about switching mowing rigs again???? :ROFLMAO:
No sir I’m set now Just have to continue waiting on DRY Ground to mow it with the big Zero’s since the front deck rear steer contraption didn’t work out for me .
A tracked skid steer with a 84-96” cutter clipping it higher would be the only thing better but way out of my league.
2002 INTERNATIONAL 4300 S/A (A67148)
2002 INTERNATIONAL...
2022 EZ-GO ELITE...
2008 SUBARU LEGACY 4 DOOR SEDAN (A65054)
2008 SUBARU LEGACY...
KUBOTA SVL97-2 SKID STEER (A65053)
KUBOTA SVL97-2...
2009 Peterbilt Pac-Mac KBF-20H Forestry Grapple Truck (A64556)
2009 Peterbilt...
2014 Ford Taurus Sedan (A64557)
2014 Ford Taurus...
