F Series vs. ZD
/ F Series vs. ZD #141
It just sets right in with no clamps or bolting. With even just 2 psi it is a snug fit between the seat and the bottom of the base. And 11-12 psi is were I usually keep it.
I'm afraid that just won't do! There must be a complicated retaining mechanism to hold that thing!
/ F Series vs. ZD #142
/ F Series vs. ZD #143
Update. Ended up keeping the ZD1211-60 bought F 2690-60 working on air pressures on the F to get rid of the excessive bouncing. Each machine has pros and con's. Just lucky that I can keep both and every once and a while can use the old BX2360 for the really rough stuff 😉
/ F Series vs. ZD #144
Update. Ended up keeping the ZD1211-60 bought F 2690-60 ... Each machine has pros and con's …
Does the F spin the inside tire doing fairly tight turns ?
My F3710 i got rid of was Horrible when going up slight hill turning :mad:
/ F Series vs. ZD #145
My F2000 does unless I engage the 4wd.
/ F Series vs. ZD #146
4wd seemed to make my F3710 spin worse.
I even fluid filled all 4 tires & it didn’t help.
The F just didn’t suit my application at all so I traded it for a ZD1611.
/ F Series vs. ZD #147
Your 770 will easily run a 9' haybine. Set it to swathe and not windrow and you can run in 3rd gear. I ran my NH479 hay mower with an 18 h.p. Yanmar on my lawn for a few years. The sickle type cutter leaves an awesome pattern in the lawn. Add a baler and sell the 'hay' to animal keepers. My Yanmar also had no trouble with a JD-14T even though the tractor did not have a separate pto clutch.
/ F Series vs. ZD #151
FWIW...the speed in which you mow depends on how rough or smooth your lawn is - mine is on the rough side...last year I bought a new Kubota 72" 1211 and I had to craw with it or I'd bounce out of the seat...therefore, I would not utilize it's speed & was not useful and I hated it. With under 10 hours on it, I traded it in for a new F3710...I found (I guess) due to it's 4 wheels on the ground and wheel base it was smoother and I was comfortable - it seemed faster. I mowing with the F3710...
/ F Series vs. ZD #152
Everybody’s application & preference is different no doubt.
Variety is good.
My new F3710 was just too long for back & forth mowing & my property is all open area.
It ABSOLUTELY WOULD NOT stay Strait mowing steep banks horizontally with the rear steer.
/ F Series vs. ZD #153
One complaint I have about the ZD1211’s is with greasing.
The rear prop shaft is tough to grease. It is somewhat accessible, but the 3 zerks on the prop shaft are hard to get a greaser attached to unless they are pointing down. It’s tough to “hand turn” the shaft, so sometimes you have to get on/off and crank engine until they are pointed down.
Anymore, I use a floor jack to lift the ass-end up so at least there’s more room to for greaser
That sort of stuff should be more easily accessible in the field.
/ F Series vs. ZD #154
The other shaft to the mower gearbox is no peach either.
For the rear shaft, I back the machine up on 8" ramps. If the zircs aren't pointing somewhat down I use a large screwdriver in the universal to rotate the shaft.
I don't ever use them, but I think there are access panels above those zirc(s)? Near the radiator.
/ F Series vs. ZD
End up putting a deposit on the machine I went to see today. It’s a 2022 zd1211 72” with 100 hours. The gentlemen was asking 14,200 I bought it for 13,000. I thought it was a good deal.
2022 EZ-GO ELITE...
Bobcat SC72 (A64127)
2022 CATERPILLAR 313GC EXCAVATOR (A65053)
2022 CATERPILLAR...
2025 LandHonor RGB-11-72W 72in Hydraulic Dual Cylinder Rock Grapple Bucket Skid Steer Attachment (A64553)
2025 LandHonor...
2025 HOMESTEADER 612IT 12FT ENCLOSED TRAILER (A67148)
2025 HOMESTEADER...
2019 GMC SIERRA HD 3500 (A63569)
2019 GMC SIERRA HD...
