John_Mc
Elite Member
- Joined
- Aug 11, 2001
- Messages
- 4,810
- Location
- Monkton, Vermont
- Tractor
- NH TC33D Modified with belly pan, limb risers & FOPS. Honda Pioneer 520 & antique Coot UTV
As a old boater which has seen the issues with ethanol in old motors deteriorating hoses and other rubber parts, have seen no issues with modern motors. If there were actual documented issues with E10 then there would be a major uproar over the world about it. Millions of motors running with E10, and if there were actual issues related back to the fuel, there would be no escape.
Its opinions, read a similar post about a specific (no names) synthetic oil. Poster said he changed his oil to the specific oil and instantly noticed it was quiter, and also noticed higher performance and fuel economy.
So when I read another say something to cover all aspects instantly and suggest all others are unable to see the sky is blue, I just ignore and smile
Well, there is a bit of an uproar in the small engine markets. Most modern small engines now have plastics and rubber parts that are more tolerant of ethanol (but not necessarily completely "ethanol-proof"). The real problem comes when you don't use the engine regularly or turn over your stock of E10 fuel quickly enough. The ethanol in the fuel will pull moisture out of the air. After ti has pulled enough, the ethanol & water settle out to the bottom of the tank. The mixture is corrosive. If you are lucky, it stays in your tank,and you just dump it out. If you are not so lucky, it corrodes parts in the carb. If you are really unlucky, since the fuel mix is also the lubricant in a 2 cycle engine, the corrosive mix sits in your bottom end corroding engine parts. It generally won't come to that if you don't store fuel for long periods of time, and especially don't leave it sitting in your engines for extended periods. Unfortunately, if you are not using that chainsaw professionally (or in some other application that forces regular use), it's all too common for someone to leave the fuel in, thinking "I'll get back to this in a few days", and then forget all about it. You might get away with it many times, but I liken it to running a red light or stop sign. The vast majority of the time, you'll get away with it. Then your luck runs out and you get a ticket - or if you are having a really bad day, you get t-boned by someone coming the other way through the intersection.
