equipment trailer wiring.
   / equipment trailer wiring. #21
Just for clarification.....
Equipment standard vs RV standard are no different in plug or layout.
It is ONLY the wire color.
The truck is always gonna have the taillights at 11 o'clock and ground at 7 o'clock on the 7-way. (Most frequent ones I check)
But an equipment trailer is gonna use a brown wire for tail lights, and an RV is gonna use the green wire.
As for trucks.....I don't think they follow a standard and use their own wire colors that make no sense
Agreed. Thats why I like the molded plug/pig tail, less room for error and less chance of corrosion. Then with a junction box you can switch colors till the cows come home:)
   / equipment trailer wiring. #22
....but they both drag along the road the same way when you loan your trailer to a "buddy" and I won't mention the jack that's at a 45* angle. 😆
I can see how that box would be helpful. On this trailer there is an electrical box mounted where all of the connections are. The difference is it doesn't have studs the wires are all connected by butt connectors and wire nuts. I had already thought about replacing that with something like you mentioned later on when I had the time. But first I wanted to get the lights somewhat right. The next time I head up the road I'll pick one of those up. Thanks
   / equipment trailer wiring. #24
You can get a junction box that Nick talks about from e-Trailer. I put them on two different pickups of mine so I could add a plug for a gooseneck in the bed. Weather tight, and a great addition.
I also would start with the assumption that the trailer wiring has "played with" and probably needs attention front to back. 👍
I'm thinking you are right about that. That connection box that's on there is a dead giveaway. I'm Also wondering why they have the clearance/side markers and the tail/running lights tied together by that jumper wire. I always thought of the clearance/side markers and running lights being the same thing but looking at the pics it looks like they put the tail and running lights together and the clearance/side markers are on a separate pin. All I know is that unless I put that jumper between the black and the brown wires everything goes haywire.
Anyway, it works with that adaptor and that's probably how I'll leave it for the time being.
I also noticed when I put the truck in reverse the side markers and the taillights all come on. Now, I don't know if that is right or not, I'm just saying that's what happens.
Would you add them to the pickup or the trailer?
I guess they do that so when something goes wrong you have to take it to them to get it fixed.:censored: I guess I need to find out just how this truck is wired; weather it's wired 7 way traditional, or 7-way RV standard. I pretty sure it's not wired 7-way heavy duty.
   / equipment trailer wiring. #28
Exactly. I'm sure that color blind people can wire a trailer plug correctly, without being distracted by the colors.
   / equipment trailer wiring. #29
That's because in commercial applications (Class 8 tractors and trailers) the taillights and marker lights are on separate circuits. I'm guessing so that there will be some lighting left if one of them craps out.
Anyway, my larger dump trailer rarely leaves the property, so on that one I removed the cord and installed a Class 8 connector. Now there's no dangling cord.
Wired up a standard Class 8 cord with an RV connector in one end for when needing lights and brakes. Now the colors were helpful. Not because of what they represented, but to keep track of which wire was what.
I really do like the Class 8 stuff as it's affordable and made to last. One of these years I'll convert the other trailers, too. Should I ever have to leave a trailer on the side of the road, chances are good that a potential thief would give up when there's no way for him to connect the trailer electrically.
   / equipment trailer wiring. #30
My junction box is mounted under the pickup. It had a factory seven pin plug and I ran the factory wiring into the junction box and ran seven wire cable back up to the plug under the bumper, and a new one to the plug in the box. I can take a picture, if you’d like. We are shelling corn right now, so I won’t be able to do that until later.
Nawh, that won't be necessary I really don't want to cut into my truck wiring. If I do install a box, I'll put it on this trailer. All my other trailers work just fine. Thanks anyway though.
   / equipment trailer wiring. #32
"If it ain't broke"..... 👍
Grounding is a common problem. If doing a re wire I'll add a wire, pick up the lights and drill and tap 3 or so points along it's path. It doesn't necessarily need to go to your new splice box but it's easy enough and ties it to the truck. 👍
   / equipment trailer wiring. #33
Speaking of, as I'm basically rewiring a trailer that's only a couple of years old, finding all kinds of odd stuff.
For example, the wiring for charging the batteries. It was about a 30-foot run of 14 gauge, to charge two batteries. Now it'll be about 11 feet of 10 gauge, for one battery. Really should be 8 gauge, but the tow vehicle also has (too) small wire sizes leading to the trailer plugs.
Also, there were fuses on both the positive and negative wires, right at the batteries. Nothing for the hydraulic pump or compressor from the batteries to them, but at the very end of the charging wires.
Yes, it wasn't broke, but could certainly stand an improvement. Now I wish I'd measured how many volts actually made it to those batteries before I tore it all apart.
   / equipment trailer wiring. #34
AGAIN......(maybe it hasn't sunk in yet as I know this can be confusing).....
BUT... THERE IS NO DIFFERENCE BETWEEN RV STANDARD AND EQUIPMENT STANDARD WHEN IT COMES TO THE PLUGS.
THE TRUCKS AND THE TRAILERS ARE WIRED EXACTLY THE SAME WAY.
THE ONLY DIFFERENCES IS RV USES DIFFERENT COLORS
so while they use the same 6 or 7 wire colors...they use them for different things. But they still wire to the plug in the exact same spot.
Plenty of charts online that show you exactly what plug does what
   / equipment trailer wiring. #35
Yes, but the OP's trailer did not have the flat bladed "RV" plug on it it had the older heavy duty 7 round pin connector which is wired differently then the blade connectors.
He is going to need to wire a new end on his trailer side with the correct wires, there is nothing wrong with his truck side wiring.
   / equipment trailer wiring. #36
I agree.
But the post from the OP that I quoted and replied to said something like home needing to figure out how the truck is wired.....and whether it's RV standard or equipment.
He is still confused and think that whatever standard has something to do with the plug or truck which it don't
It ain't rocket science. You have 5 wires and a ground. Find the ground.....put 12v to the rest one at a time and see what comes on. Wire a 7-way plug and be done. Literally less than an hour provided wiring underneath trailer is good as are lights. This is just trying to make a mountain out of a molehill and overcomplicate things that really don't matter
   / equipment trailer wiring. #37
No need to take it to them, unless you have no concept of how to test 12 volt electrical systems and/or have no idea how to search the internet/youtube in order to learn. If you want to know what does what in the outlet on the pickup, just test the connections. As LD1 has pointed out several times, the two 7 way flat connector wiring types are exactly the same, other than the colors. Those titles "7 way RV" and "7 way traditional" only apply to the trailer side, not the truck side. The truck side is more than likely going to have different colors than either one. You can't rely on wire color at all when diagnosing this stuff, you have to test the functions.
Ok I mis-spoke in that post I started it and had to leave for a bit and when I came back just put down what was on my mind at that time. To begin with, I'm not working on my truck. I have three other trailers that work fine hooked up to my truck. The problem lies with this new/old trailer I bought.
I guess I should also bring up that I am smart enough to search the internet and that also I was a boat mechanic for 25 years and have wired hundreds of boat trailers, so I do know a little about wiring. I never had the reason to work on simi trailers or heavy equipment trailers with electric brakes and such.
This trailer was hooked to an older Mack dump truck and from what I gather from the people that had it, everything worked ok for what they used it for. They plugged it right into the truck plugin and went on about their business.
My truck came into play because it didn't like it when I plugged it into the truck wiring. It will work fine hooked up with that heavy adaptor plug. All this started when I asked about wiring it straight. I do understand that the wire colors don't mean much with this application and I figured that out the first time I looked at the adaptor cable. What I don't understand is that damn brown jumper wire that jumps over to the black wire on the trailer plug. All I know is, with the adaptor hooked up everything works as long as I keep that jumper wire in place. If I remove it nothing works and with it hooked up straight jumped or not the truck doesn't like it. My dash displays, right turn error, left turn error, running light error. It's sending signals to the turn signals and running lights, but the signal lights flash really fast, like the older signal light switches used to do when you hooked up to a trailer. It's got to have something to do with that jumper wire. How to get rid of that is what I'm working on now.
This turned into 4 pages mainly because I try to be courteous enough to respond to what other's post to me and if that's wrong, then I'll stop doing that. I think there are a few folks here that understand what I trying to explain, and I guess it just flies over the heads of really smart people here.
   / equipment trailer wiring. #39
Some semi trucks have 2 separate wires for the trailer lights tail and marker lights.. The older trucks had separate wires for brake and turn signals..
   / equipment trailer wiring. #40
Yes, tractor trailers and other Class 8 vehicles have those separate circuits, which is why there has to be a jumper (between 5 and 8 if memory serves me. It's been a few years) to combine the marker and taillights for use with a regular trailer's RV wiring.
If the trailer is wired to work with a vehicle that has the commercial plugs, either an adapter is needed, or changing the plug to a flat 7 and wire it accordingly.
Someone posted a chart earlier that clearly shows the differences.
2019 Jeep Grand Cherokee SUV (A59231)
2019 Jeep Grand...
1978 Gray 48RM Vertical Boring Machine (A59213)
1978 Gray 48RM...
2011 Ford Expedition 4x4 SUV (A59231)
2011 Ford...
*Selling at Royal Auction Tampa, FL Location* (A59228)
*Selling at Royal...
Kubota RTV X1140 (A60462)
Kubota RTV X1140...
(8) UNUSED 9' X 5' WROUGHT IRON SITE FENCE (A60432)
(8) UNUSED 9' X 5'...
