Backhoe Encounter: Woods Backhoe for BX
/ Encounter: Woods Backhoe for BX #1
JimMorrissey
Southern Maine (now)
'05/'06 L39 TLB
Today, I actually saw the new Woods backhoe for the BX at a local dealer. I must say that is looks to be an excellent implement. It was still strapped to the pallet, but the dealer's man was in the process of unpacking and figuring it out himself. It has what looks like a nice heavy duty sub-frame. The welds, paint, and general tooling looked excellent. I believe it will be a fine addition to any of the little Kubotas. They intend to give a demonstration when it's complete. I will report back if I am able to participate.
No definite word on pricing, as the dealer hasn't been invoiced yet. I'd figure around 5K.
Jim
/ Encounter: Woods Backhoe for BX #2
Jim, I saw one of those units at the Empire Farm Days. I agree, it looked like a excellent unit. I have not looked very closely at the BX23 BH's, but off hand, the Woods appeared more ruggedly built, and the fit and finish was excellent. The Woods rep gave me a price of $5800.
Will
/ Encounter: Woods Backhoe for BX #3
Some questions I'm wondering about:
Is the backhoe powered off of the tractor hydraulics somehow, or does it/can it use a PTO-driven hydraulic pump?
Can the subframe be left on & still mount the MMM?
What do they do with the seat?
What do they do with the 3ph drag arms?
regards,
Mahlon
Mahlon,
Yes, the hoe is powered via tractor hydraulics.
The dealer did not know yet if the subframe will be left on & still be able to mount the MMM. I asked the same question. It looked to me like it might come off so you can attach a mower deck, but I could be wrong.
I believe they swap the seat out so it flips like the BX 22s
Not sure about the 3PT arms....
The cylinders look huge for such a small hoe. It's a nice setup.
Jim
/ Encounter: Woods Backhoe for BX #5
The subframe stays on the tractor and allows for the MMM to stay attached and used just like the BX23/23. The 3-point arms are removed similar to the BX22/23. I was quoted $4,500 by my local dealer.
/ Encounter: Woods Backhoe for BX #6
<font color="blue">"the Woods appeared more ruggedly built"</font>
What exactly did you see that gave that impression?
/ Encounter: Woods Backhoe for BX #7
</font><font color="blue" class="small">( The Woods rep gave me a price of $5800.)</font>
When Woods anounced the release, someone reported that the MSRP was $5500. With quotes already ranging from $4500 to $5800, seems it'll pay to shop around. Since this unit is designed to work with several subCUTs by way of different sub-frames, I wonder whether there is any difference in price based on differing sub-frames? I wouldn't think so. I also read someone's statememt that the lift arms must be swapped out with "split" lift arms; wonder if that's accurate? Also, did these quotes include or not include: a) subframe mounting, b) swapping out seats &/or lift arms, c) shipping charges, d) delivery charges, e) tax?
/ Encounter: Woods Backhoe for BX #8
It seemed that the Woods was generally made with heavier material. Now, as I am not in the market for one, I did not compare specs or ask any detailed questions, so my impression may not be correct.
Will
/ Encounter: Woods Backhoe for BX #9
My quote of $4,500 was with the subframe mounting kit and 12" bucket.
/ Encounter: Woods Backhoe for BX #10
Will_C
Thanks for the response.
KNotMe
/ Encounter: Woods Backhoe for BX #12
</font><font color="blue" class="small">( Is it the BH6000 Groundbreaker-X Backhoe?)</font>
Yeah, that's it. That site, however, does NOT answer most of the questions on this thread.
/ Encounter: Woods Backhoe for BX #13
Well, partially.
The specs are there, though they don't discuss what modifications are required to attach the hoe. There are some photo's that help some of us who haven't seen the backhoe better understand the intent of the connections.
/ Encounter: Woods Backhoe for BX #14
The 3-point arms are attached just like the BX22/23. The subframe mount replaces the single one piece rod with a split rod. All you do is remove the pins and pull off the arms. The subframe is just as strudy as the factory Kubota. It may even be better since it is used in addition to the existing rear fender supports. The seat mounting has a swivel plate in the kit. It also comes with the all hydraulic pieces for the rear remote connections. It is a very nice backhoe.
/ Encounter: Woods Backhoe for BX #15
Actually saw one of these mounted on a BX2230 at the Penn State Ag Progress Days. Looks like a well built unit. There was some modification to the seat to allow it to pivot to face the rear but unless you are really short, the top of the ROPS will be in your face. Guess that's why the BX23 has a taller, folding ROPS.
/ Encounter: Woods Backhoe for BX #16
I have a bx22 would the woods buckets fit a bx22 backhoe. They only make a 10" and a 12" bucket for the backhoe. The woods has an 8" and a 16". I would like to own an 8" bucket for my backhoe.
/ Encounter: Woods Backhoe for BX #17
I have wondered the same thing myself - if somebody besides Kubota makes buckets that would fix on the BX23 backhoe. I have a 12" but have had more than a few instances when a 16" would have come in very handy.
New 5400LB, Rachet Binders and G70 Chains (A62679)
New 5400LB, Rachet...
New Mini Skid Steer Grapple Bucket (A62679)
New Mini Skid...
2025 Kivel 48in Forks and Frame Skid Steer Attachment (A61572)
2025 Kivel 48in...
2001 Blaw-Knox PF 150 Paving Machine  (A62679)
2001 Blaw-Knox PF...
2004 Quincy QSI500 Air Compressor (A61572)
2004 Quincy QSI500...
New/Unused CFG Industrial MH12RX Mini Excavator (A65583)
New/Unused CFG...
