Enclosed Trailer flooring question.
/ Enclosed Trailer flooring question. #1
Scott85
Elkton, Va
nothing yet
I have a 7x12 enclosed trailer and would like to have some tie downs to haul a 4 wheeler and I am not scared to do the work myself but I know the road side of the plywood has some type of coating right? What can I spray to cover the holes and hardware I installed? Thanks!!
/ Enclosed Trailer flooring question. #2
If it's not treated wood already. I would spray it with rubberized under coating . You can buy it in a spray can at auto parts or walmart. Others may have better ideas
Thank you, that's the idea I have just seeing if it's the right one. Sorry I posted this in the wrong spot I didn't see the trailer section till a minute ago.
/ Enclosed Trailer flooring question. #4
Thank you, that's the idea I have just seeing if it's the right one. Sorry I posted this in the wrong spot.
No big deal.. I post in the wrong spot at times. You'll still get answers.
/ Enclosed Trailer flooring question. #5
I used E-track on the floor of my new trailer to tie down my zero turn mower and side by side. It works great and you have multiple anchor spots. I just strap over one tire on each side, usually one front and one rear on the SxS, and it works like a charm.
I looked at that and that probably what I'll go with. Did you spray undercoating underneath where the bolts went through the floor?
/ Enclosed Trailer flooring question. #7
No, I didn't use bolts, I used lag screws. But mine is also an open flat trailer with 2x6 floor. But you can still use the lag screws. I put the screws in every other hole on the e-track. It does take a lot of screws but I didn't want to be drilling holes in the floor if I didn't have to.
/ Enclosed Trailer flooring question. #8
I used e-track on my 6x12 enclosed trailer as well. As with AndersonFarm, I just used screws to attach. I also installed two Condor Chocks for the motorcycles. Those were bolted to the floor with the holes going all the way through. I used washers on both sides for the chock's holes, but I didn't coat the holes or spray anything underneath. Now - having said this - my trailer was stored inside an enclosed building and didn't see much overall use, so your mileage may vary.
2023 Unverferth 3PT 6 - FT Perfecta Field Cultivator (A63688)
2023 Unverferth...
iDrive TDS-2010H...
2023 KENWORTH T680 T/A 6X4 SLEEPER TRUCK TRACTOR (A59914)
2023 KENWORTH T680...
2016 Ram 5500 Flat Bed (A63688)
2016 Ram 5500 Flat...
New Webbing Slings, Polyester, 6:1 & 15" (A62679)
New Webbing...
2023 JOHN DEERE 550P LGP CRAWLER DOZER (A64279)
2023 JOHN DEERE...
