Enclosed Trailer flooring question.
/ Enclosed Trailer flooring question. #1
Scott85
Elkton, Va
nothing yet
I have a 7x12 enclosed trailer and would like to have some tie downs to haul a 4 wheeler and I am not scared to do the work myself but I know the road side of the plywood has some type of coating right? What can I spray to cover the holes and hardware I installed? Thanks!!
/ Enclosed Trailer flooring question. #2
If it's not treated wood already. I would spray it with rubberized under coating . You can buy it in a spray can at auto parts or walmart. Others may have better ideas
Thank you, that's the idea I have just seeing if it's the right one. Sorry I posted this in the wrong spot I didn't see the trailer section till a minute ago.
/ Enclosed Trailer flooring question. #4
Thank you, that's the idea I have just seeing if it's the right one. Sorry I posted this in the wrong spot.
No big deal.. I post in the wrong spot at times. You'll still get answers.
/ Enclosed Trailer flooring question. #5
I used E-track on the floor of my new trailer to tie down my zero turn mower and side by side. It works great and you have multiple anchor spots. I just strap over one tire on each side, usually one front and one rear on the SxS, and it works like a charm.
I looked at that and that probably what I'll go with. Did you spray undercoating underneath where the bolts went through the floor?
/ Enclosed Trailer flooring question. #7
No, I didn't use bolts, I used lag screws. But mine is also an open flat trailer with 2x6 floor. But you can still use the lag screws. I put the screws in every other hole on the e-track. It does take a lot of screws but I didn't want to be drilling holes in the floor if I didn't have to.
/ Enclosed Trailer flooring question. #8
I used e-track on my 6x12 enclosed trailer as well. As with AndersonFarm, I just used screws to attach. I also installed two Condor Chocks for the motorcycles. Those were bolted to the floor with the holes going all the way through. I used washers on both sides for the chock's holes, but I didn't coat the holes or spray anything underneath. Now - having said this - my trailer was stored inside an enclosed building and didn't see much overall use, so your mileage may vary.
John Deere LX5 5ft. Rotary Brush Cutter Tractor Attachment (A61572)
John Deere LX5...
Kubota KX080-4 (A64126)
Kubota KX080-4...
2008 INGERSOLL RAND G240-191KW GENERATOR (A63276)
2008 INGERSOLL...
Exmark C2-96 (A64127)
1996 Chevrolet 1500 (A64127)
1996 Chevrolet...
2024 Schulte 5026 Batwing Rotary Cutter (A63688)
2024 Schulte 5026...
