sodamo
Super Star Member
- Joined
- May 20, 2004
- Messages
- 17,005
- Location
- Big Island, HI
- Tractor
- LS XR4140H (Mine) BX2380 (wife’s)
In the process of taking my cottage off is standalone solar PV electric and hooking in to my main system at the house. You can see the trench work here: http://www.tractorbynet.com/forums/kioti-owning-operating/245828-kb-2375-trench.html
I am running approx 375 ft of #2 copper from my main distribution panel to a sub panel at the cottage. 70AMP breakers, 240 volt. Loss will be just over 3%.
My question is regarding ground wire. Do I need to run 2 separate grounds panel to panel or is a single sufficient. I can buy 3 conductor w/ ground to run in my 2inch conduit. If I need the 2nd ground I suspect I'll have to run 3 separate conductors plus the 2 grounds. Naturally, the 3w/grd would be easier for me to handle. This is not a grd rod issue as there are double rod.
A friend is bringing over a copy of the NEC, but thought I'd tap into the BN brain trust.
David
David
