Richard
Super Member
- Joined
- Apr 6, 2000
- Messages
- 5,051
- Location
- Knoxville, TN
- Tractor
- International 1066 Full sized JCB Loader/Backhoe and a John Deere 430 to mow with
Scenario: I'm finishing a room downstairs and will be moving my electronics down there (stereo/tv...)
I've been told that sometimes, one factor in getting ground loop hums in a stereo system is different components being plugged into different circuits (different plugs leading to different breakers in the panel box)
True, not true... I dunno.
So... in light of that and actually, irrelevant to that situation, I ask is the following a known breach of code?
If you have a panel box in the garage and want to run say, three outlets to your stereo room. One on the left wall, one on the back wall and one on the right wall. Each outlet is a SINGLE outlet on its OWN breaker at the box. They are not daisy-chained on the same circuit.
So, you have three different runs from the box to each outlet location and this run will be 12-2 wire w/g.
Fine/dandy.
Here's the question.....
Is there any benefit or more importantly, breach of code, if you went to box 1 and attached a SECOND ground wire and ran it through the walls to outlet #2 and then to outlet #3?
So, each outlet has a single 12/2wg wire from outlet to panel box and a SECOND ground wire going from box to box such that each box is tied to the next?
This way, if they have 50' of wire for each hot run, they might instead have 10/15' of distance before they find a common ground with each other.
If it's over kill or stupid...that's one thing.... if it's dangerous for some reason, that's another and why I'm asking.
btw, my BIL is an electician and will be doing all the hooking up, I'm just preparing to do all the grunt work and pull the wires through the walls.
Fine/dandy.
