Electric Drive Motor Retrofit
/ Electric Drive Motor Retrofit #103
Looks like it’s all hydraulic too. Pumps driven by the electric motor. Seems like that would be a fairly easy conversion to the PT.
/ Electric Drive Motor Retrofit #104
For the 20% efficiency gain, I would think that they would have it be electric drive vs hydraulic driven off an electric motor.
That is how most electric forklifts are setup.
Aaron Z
/ Electric Drive Motor Retrofit #105
Works for 2 hours and charges for 4 hours. That’s exactly what I’ve been looking for.
/ Electric Drive Motor Retrofit #106
It said something about it can work while it's charging.... what could that be about?
/ Electric Drive Motor Retrofit #107
I assume in a barn or something, where your not moving far, you could run it while plugged in.
/ Electric Drive Motor Retrofit #109
Maybe to power stationary things like water pump, chipper, splitter, concrete mixer, massage recliner, hot tub you know the usual things.
/ Electric Drive Motor Retrofit #111
I've seen one of their engine-powered machines here in town working for a contractor. I haven't been able to get up close to it. From everything I've read, they are really well built machines. Gotta be very expensive.
I noticed in some of the literature, they articulate but they don't oscillate. It mentioned lowering the tip-over point in a machine that size. I'm guessing that since it can lift so high, that would be an issue.
2014 GMC Sierra SLT 4x4 Crew Cab Pickup Truck (A59230)
2014 GMC Sierra...
2017 Ford Fusion Sedan (A59231)
2017 Ford Fusion...
GRID SHAPED BUCKET FOR MINI EXCAVATOR (A58214)
GRID SHAPED BUCKET...
2009 Kubota RTV1140 (A57148)
2009 Kubota...
CH and E 2909T 6in Towable Dewatering Pump (A59228)
CH and E 2909T 6in...
UNUSED SDLANCH MINI EXCAVATOR RIPPER (A60432)
UNUSED SDLANCH...
