MossRoad
Super Moderator
- Joined
- Aug 31, 2001
- Messages
- 63,317
- Location
- South Bend, Indiana (near)
- Tractor
- Power Trac PT425 2001 Model Year
I think (that's scary) that the tram pump to motor mount is an industry standard size mount. I don't know the spec, but it's an industry standard. You could probably re-use it with no problem on the tram pump side. On the gas motor side, it's also an industry standard bolt pattern. I'd start looking at the electric motor bolt patterns and shaft sizes and lengths first to see if there are any electric motors that fit that mount. But I doubt it. So, find a suitable motor, determine it's bolt pattern, drill the gas motor side of the existing mount to match that electric motor bolt pattern....
or you may have to weld a plate to that mount to get the hole size correct, or perhaps there's an industry standard plate already made for that electric motor that could be welded onto the existing gas motor side of that pump adapter, you get the idea.
Then it would be a matter of determining the shaft length and size of the electric motor, cutting length to fit if necessary, and getting a love-joy connector that will fit the electric motor shaft and mate to the other love-joy connector that's already on the tram pump.
That was long winded. :laughing:
