Dump trailer hydraulics
/ Dump trailer hydraulics #1
10711
Littleton, CO
Kioti ck30
I purchase a 14' dump trailer. We tested the dump when I purchased it.. Battery power was provided by the pickup truck that was wired to the battery on the dump tailer. I got it home and could not get it to raise. I charged the battery on the trailer but still did not raise. I click the up and down buttons but no movement or noise. Any advice for troubleshooting advice?
/ Dump trailer hydraulics #2
You should start with testing the battery. Sounds like it will not hold a charge. A full charging and a load test will verify the batteries state.
Make sure it has water in it if it is a maintenance type battery.
/ Dump trailer hydraulics #4
The thing I forgot to mention was check for loose wires too.
I took the battery to an auto parts store to check it out. Appears to be ok. Checked the wires and appears avert thing is tight
/ Dump trailer hydraulics #6
I think but don't know there should be some action from 1 battery but what I do know is when my son dumps his it's plugged into the truck as well with the motor running this also helps keep a charge in the trailer battery. His likes lots of electricity.
/ Dump trailer hydraulics #8
My 14' SureTrak dump trailer has a mechanical lock to prevent the bed from dumping, I've never used it but it's there. Just a thought.. good luck...
/ Dump trailer hydraulics #9
/ Dump trailer hydraulics #10
Not sure whether OP figured it out. I would put jumper cables from a known working vehicle (running) battery and see what happens. Even if the original battery is dead that will move the bed. If a no-go, problem is elsewhere.
2024 DEVELON DL250-7 WHEEL LOADER (A63276)
2024 DEVELON...
2003 McCormick XTX 185 XtraSpeed Tractor (A63688)
2003 McCormick XTX...
2016 Ford F-150 4x4 Crew Cab Pickup Truck (A61567)
2016 Ford F-150...
(2) DOUBLE AXLE FENDERS (A64280)
(2) DOUBLE AXLE...
UNUSED ATSPOWER ELECTRIC WINCH (A64281)
UNUSED ATSPOWER...
2007 Volvo VNL Truck Tractor (A63689)
2007 Volvo VNL...
