Dump trailer hydraulics
/ Dump trailer hydraulics #1
10711
Littleton, CO
Kioti ck30
I purchase a 14' dump trailer. We tested the dump when I purchased it.. Battery power was provided by the pickup truck that was wired to the battery on the dump tailer. I got it home and could not get it to raise. I charged the battery on the trailer but still did not raise. I click the up and down buttons but no movement or noise. Any advice for troubleshooting advice?
/ Dump trailer hydraulics #2
You should start with testing the battery. Sounds like it will not hold a charge. A full charging and a load test will verify the batteries state.
Make sure it has water in it if it is a maintenance type battery.
/ Dump trailer hydraulics #4
The thing I forgot to mention was check for loose wires too.
I took the battery to an auto parts store to check it out. Appears to be ok. Checked the wires and appears avert thing is tight
/ Dump trailer hydraulics #6
I think but don't know there should be some action from 1 battery but what I do know is when my son dumps his it's plugged into the truck as well with the motor running this also helps keep a charge in the trailer battery. His likes lots of electricity.
/ Dump trailer hydraulics #8
My 14' SureTrak dump trailer has a mechanical lock to prevent the bed from dumping, I've never used it but it's there. Just a thought.. good luck...
/ Dump trailer hydraulics #9
/ Dump trailer hydraulics #10
Not sure whether OP figured it out. I would put jumper cables from a known working vehicle (running) battery and see what happens. Even if the original battery is dead that will move the bed. If a no-go, problem is elsewhere.
2015 NEW HOLLAND BOOMER 41 TRACTOR (A64280)
2015 NEW HOLLAND...
2019 John Deere 9470RX Tractor (A63111)
2019 John Deere...
1836 (A64280)
1836 (A64280)
UNUSED WOLVERINE HYD TILLER (A64281)
UNUSED WOLVERINE...
Hays LT-1 Tender (A61307)
Hays LT-1 Tender...
2004 International 4400 Single Axle Dump (A62613)
2004 International...
