Dump trailer hydraulics
/ Dump trailer hydraulics #1
10711
Littleton, CO
Kioti ck30
I purchase a 14' dump trailer. We tested the dump when I purchased it.. Battery power was provided by the pickup truck that was wired to the battery on the dump tailer. I got it home and could not get it to raise. I charged the battery on the trailer but still did not raise. I click the up and down buttons but no movement or noise. Any advice for troubleshooting advice?
/ Dump trailer hydraulics #2
You should start with testing the battery. Sounds like it will not hold a charge. A full charging and a load test will verify the batteries state.
Make sure it has water in it if it is a maintenance type battery.
/ Dump trailer hydraulics #4
The thing I forgot to mention was check for loose wires too.
I took the battery to an auto parts store to check it out. Appears to be ok. Checked the wires and appears avert thing is tight
/ Dump trailer hydraulics #6
I think but don't know there should be some action from 1 battery but what I do know is when my son dumps his it's plugged into the truck as well with the motor running this also helps keep a charge in the trailer battery. His likes lots of electricity.
/ Dump trailer hydraulics #8
My 14' SureTrak dump trailer has a mechanical lock to prevent the bed from dumping, I've never used it but it's there. Just a thought.. good luck...
/ Dump trailer hydraulics #9
/ Dump trailer hydraulics #10
Not sure whether OP figured it out. I would put jumper cables from a known working vehicle (running) battery and see what happens. Even if the original battery is dead that will move the bed. If a no-go, problem is elsewhere.
LOT OF SCRAP IRON AROUND CEDAR TREE (A63291)
LOT OF SCRAP IRON...
KMC 6-36 (A64119)
KMC 6-36 (A64119)
2012 International WorkStar 7300 AWD Altec DC47TR Insulated Digger Derrick Truck (A60460)
2012 International...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
New Holland TC21 (A62177)
New Holland TC21...
Massey Ferguson 4710 (A60462)
Massey Ferguson...
