3-Point Hitch Dropping 3 point linkage
/ Dropping 3 point linkage #1
marthaiseki
Lewes England
Kioti CK35 TYM 237
HI everyone. I've had a ck35 for a few years now which is generally pretty good, but now and then I get a problem with the 3 point linkage. When I raise an implement up it drops maybe an inch then jerks back up then it drops an inch then up and effectively starts bouncing which is pretty annoying! Then less frequently it will drop slowly to the ground.
Sometimes it won't happen for a few months.
Any help much appreciated.
/ Dropping 3 point linkage #2
Somewhere down near the floor and around the base of your seat is the knob/lever that controls the raising/lowering speed of the 3-point linkage. Make sure it has not accidentally been turned to almost fully off. I had the same problem on my previous tractor and it was just that the "speed knob" got tweaked.
Also check that your hydraulic fluid is up to full.
/ Dropping 3 point linkage #3
I wonder how he made out? I bet you are correct on the fix.
Thanks guys I've started watching that you tube video and it is exactly what it does. I'll watch the rest for the fix and hopefully will get it sorted. I'll let you know!
2016 FORD F550 CREW CAB SERVICE TRUCK (A59905)
2016 FORD F550...
Wolverine RPR-12-72W Skid Steer Ripper  (A62679)
Wolverine...
John Deere 350B Crawler Dozer (A65579)
John Deere 350B...
2013 KENWORTH T800 BOBTAIL VACUUM TRUCK (A65643)
2013 KENWORTH T800...
2022 EZ-GO ELITE...
New/Unused Receiver Hitch Ripper (A65583)
New/Unused...
