Kioti DS 4110 - can't raise three point
/ Kioti DS 4110 - can't raise three point #1
dbmead
Kioti ds4110
So I kind of inherited a Kioto DS4110. My prior experience is with Kubota. A couple weeks ago, jumped on this Kioti and did some work. Went to swap out box blade with a bush hog and all was no problem. Dropped the bush hog and parked it.
Went today to put box blade back on, and it wouldn't raise after connecting the 3 point. Unhooked it and the arms still won't raise. I can go back and lift them no problem. Front loader and PTO work fine.
I am willing to bet this is some form of operator error since all worked fine 2 weeks ago. I can tell when I pull the raise lever it is connected. I don't hear anything and no engine bog. I believe the rear remote lever is next to the raise/lower. Pretty sure I tried in both positions, but it was suggested elsewhere to try again so I will. I can upload pic if needed. My manual has a different config than what I have, so not sure which position it should be in.
Any likely culprits?
