Draw bar - Hitch
/ Draw bar - Hitch #11
Soundguy said:
then get a drawbar lock from tsc for about 15$.. soundguy
if you go that route, and have delux 3pt with adjustable end links, the cheepy drawbar lock will not fit. youll need a version that attaches at the edges and comes up to attach to the top link.
ask me how i know....
/ Draw bar - Hitch #12
Same with my ford 5000.. deluxe ends..e tc.. However if you have thet.. just get an a-frame kit and turn your drawbar into a 3pt implement with a toplink bracket... cost is about 20$ from a tisco dealer for the 2 upright parts and nuts/bolts.
Soundguy
/ Draw bar - Hitch #13
Soundguy
see thats what i ment.... "a-frame kit"
look at you with your fancy names ;)
/ Draw bar - Hitch #14
I took two pieces of 3/8 inch by 4 inch flat bar stock. I then drilled a 5/8 inch hole near the end of the bar on each piece.
I then got a reciver tube that bolts to a bumper that has holes to mount it with.
I drilled holes the same size as the reciever tube mounts in the other end of the 2 pices of flat stock
I put the pieces of flat stock in a vise and bent them 90 degrees near the hole for the reciever hitch.
You can now bolt them to the receiver hitch and the draw bar this will give you a fairly inexpensive three point receiver hitch with no welding.
/ Draw bar - Hitch #15
I got a ball and bolted it to my drawbar, and made a drawbar lock out of "drops" from a local welding/steel supply place. Cost was about 10 bucks for the ball and a couple bucks for the metal.
/ Draw bar - Hitch #16
The Drawbar lock from tsc works pretty good. I like the stuff you guys fabricated alot better though. lol
/ Draw bar - Hitch #17
Here is a sideview of mine that I made from a crash damaged receiver hitch that I picked up free at a body shop. It is bolted to the drawbar with 3/4" bolts. As you can see in the picture I have the cross pin on the inside so I can keep the attachments as close to the tractor as possible. It has a lot of uses. I made a frame to mount my sprayer to it. I don't have a picture but I also made a frame to lift and pull my 4' springtooth drag. Once you have a 2" receiver hitch mounted on a 3PTH drawbar there are many things that you can attach to it with 2" X 1/4" square tube. It is extremely strong and a lot easier than making a standard 3PTH mount for each implement.
/ Draw bar - Hitch #18
Just make sure you have something to keep your 3pt from raising.
I almost dumped a trailer that way. Boy did I feel stupid, not
remembering that the 3pt would just lift up...
A chain from the top link pin to a regular (length-wise) drawbar
is the usual trick.
1987 FORD F-700 FUEL TRANSPORT TRUCK (A58214)
1987 FORD F-700...
HYSTER S60FT STRAIGHT MAST FORKLIFT (A59823)
HYSTER S60FT...
2004 VE ENTERPRISES 500BBL FRAC TANK (A58214)
2004 VE...
2025 AGT STSD10 72" Grain Drill (A60463)
2025 AGT STSD10...
John Deere R75 (A60463)
John Deere R75...
Hyster H155 XL Forklift (A59213)
Hyster H155 XL...
