Snow Draft control using back blade to plow snow
/ Draft control using back blade to plow snow
In 10 years we have had 3 snows where a blower help from depth perspective. We mostly get3-8" storms. Blade on my 4 wheeler does good. I want to get the tractor set up to do more with heated cab
/ Draft control using back blade to plow snow #22
I use a 7' blade similar to yours. I run my blade very vertical. Top link almost as short as it will go.
I use my blacktop section of driveway to set the blade. I plow it clean then backup and set the 3 point stop where the blade just touches the blacktop. This setup gets me down to the very top of the gravel. I'll rake out a few of the larger stones but not very much. Then as I go through valleys I have to make small adjustments. But for most of my plowing I leave the blade set on the stops. We're like you, mostly plowing snow on unfrozen ground. Plow over a half mile of driveway and an acre parking lot like this. When I get to chip 'n seal I set the blade down harder. As it's usually compacted by the neighbors.
Zero Turn Mower (A59231)
Zero Turn Mower...
John Deere 5525 (A60462)
John Deere 5525...
Tufline PT 12' Box Blade (A64119)
Tufline PT 12' Box...
2013 CATERPILLAR 299D SKID STEER (A60429)
2013 CATERPILLAR...
2018 HINO 338 4X2 S/A 26FT CDL REQUIRED BOX TRUCK (A59912)
2018 HINO 338 4X2...
2016 VOLVO EC250EL EXCAVATOR (A64279)
2016 VOLVO EC250EL...
