Snow Draft control using back blade to plow snow
/ Draft control using back blade to plow snow
In 10 years we have had 3 snows where a blower help from depth perspective. We mostly get3-8" storms. Blade on my 4 wheeler does good. I want to get the tractor set up to do more with heated cab
/ Draft control using back blade to plow snow #22
I use a 7' blade similar to yours. I run my blade very vertical. Top link almost as short as it will go.
I use my blacktop section of driveway to set the blade. I plow it clean then backup and set the 3 point stop where the blade just touches the blacktop. This setup gets me down to the very top of the gravel. I'll rake out a few of the larger stones but not very much. Then as I go through valleys I have to make small adjustments. But for most of my plowing I leave the blade set on the stops. We're like you, mostly plowing snow on unfrozen ground. Plow over a half mile of driveway and an acre parking lot like this. When I get to chip 'n seal I set the blade down harder. As it's usually compacted by the neighbors.
KUHN GA4121GM 11' ROTARY HAY RAKE (A64277)
KUHN GA4121GM 11'...
Case 950 8 Row Air Planter (A63118)
Case 950 8 Row Air...
Titan 20.5-25 Tires (A65640)
Titan 20.5-25...
2020 INTERNATIONAL LT625 T/A SLEEPER TRUCK TRACTOR (A59914)
2020 INTERNATIONAL...
New/Unused Wolverine 78in Quick Attach Smooth Bucket (A65583)
New/Unused...
213063 (A64276)
213063 (A64276)
