Downhill smoking
/ Downhill smoking #1
ralanh
NC
2007-8 JM 354LE
I have a 2008 Jinma 354LE. this is a great tractor. While mowing downhill, when the left side of the tractor (injector side) is at the lowest point, the tractor begins popping and smoking from the exhaust. Judging from the smell,the smoke is definitely oil. This has been happening since day one, but only downhill. Once I turn out of the decline the popping stops, then the smoke clears and it runs fine. Please do not tell me to mow uphill, I mow several acres in a mountain setting and eventually I must go down after going up.I would appreciate any thoughts or comments.
_________________
/ Downhill smoking #3
I seems that this issue was just addressed somewhere, and the finding was that the crankcase evacuator hose that leads from the valve cover to the intake manifold is the culprit. For some reason unbeknownst to this writer, the oil is not draining down fast enough from the top end back to the crankcase, and flowing over into the intake manifold. Seems to me that an easy fix would be to relocate the hose into the top center of the valve cover. Easier yet - stay on the flat.
:D
/ Downhill smoking
Matt, that is a good (controversial) question. the manual states the oil capacity to be 6.3 quarts. the dipstick has two holes, which are to my understanding, are the minimum/maximum indicators. Thus filling to the maximum will take 8 quarts. Maybe the dipstick is the culprit.
/ Downhill smoking
Bob I appreciate your thoughts. How do you think I can mow in a mountain setting and stay in the flat? I am looking for realistic responses to this post not comedy
/ Downhill smoking #6
First of all I apologize for not keeping a straight face.
Secondly, you would have to have at least ten gallons of oil in the base before it could get into the combustion chamber, and by that time I think you would notice a little "leaking or dripping" somewhere.
Bear in mind that these engines' oil pumps can loose suction on steep grades - they do not have dual suction tubes or split sumps like the high-end equipment.
If I were you I would pop that valve cover to see why the oil isn't returning to the base in a timely fashion. I offered a suggestion for the fix - take it or leave it.
It also would be a big help to others to know what engine you have, since several seem to be available.
I do know a little about engines.
/ Downhill smoking
Thanks for the feedback. The engine is a 395E1 (three cyl)
/ Downhill smoking #8
Ralanh, Bob may have a point on the valve cover vapor hose. At looking at my 284 jinma my hose comes out the top and to the rear of the cover , but it points down to the intake.
I would disconnect the hose at the valve cover and plug the hose so you don't create a vacuum leak to the intake, and then do a test , if you get oil on your engine ,but the problem stops, then your valve cover is flooding with oil, and a oil/air separator will have to be installed. or a check valve installed. Take pictures.
/ Downhill smoking
It is fixed,
thanks for the help
/ Downhill smoking #10
It is fixed,
thanks for the help
Thank you for telling us what the problem really was and how it was fixed. We will now be able to share that with others who have a similar problem!
RonJ
/ Downhill smoking
Hi Ron, I like your sense of humor/sarcasm? lol
I had an agenda this am when I posted. I had to get parts for the power steering leak. Another saga/another post
the downhill smoking was indeed burning oil. The original (factory)valve cover vent is located at the left front of the valve cover. The vent tube was bent down directly into the intake. When the tractor was traveling (downhill) with the left front at the lowest point the oil would get to the vent tube and the intake vacuum would take over.
the fix: I capped off the valve cover, cut a neat hole in the oil fill cap, placed a 90 degree(barbed outside/threaded inside) elbow in the cap and installed a new hose to return to the intake. It is crude but it will work until I bring the tractor home for the winter.
I ran the tractor down every hill that produced the sputtering and could not make it smoke, skip, or sputter once.
Credit will actually go to Bob Rooks.
I never really paid attention to the placement of the vent.
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
2015 Freightliner M2 106 AWD Altec AT37G Bucket Truck (A60460)
2015 Freightliner...
2011 Ford E-350 Passenger Van (A61573)
2011 Ford E-350...
2026 Electric Tricycle (A64194)
2026 Electric...
2022 CATERPILLAR 310 EXCAVATOR (A62129)
2022 CATERPILLAR...
JLG E300AJ (A60462)
JLG E300AJ (A60462)
