Down shifting
/ Down shifting #1
curtisg710
For as long as I remember I’ve never been able to down shift my tym433. It goes up in gears fine but when going down I have to come to a stop basically. Does any else have this issue?
/ Down shifting #2
Dont have a shuttle shift but looking at the manual, I would think you should be able to do what you ask. I see the only time it requires a complete stop is when shifting ranges. Sorry, not much help here.
/ Down shifting #3
I can up and down shift easily on my Branson. Which is more or less similar to your TYM.
I'm not sure what could be wrong either.
/ Down shifting #4
My M6040 is hydraulic shuttle. I can go up/down the four gears within either the high or low range without stopping. The clutch must be depressed. To change range - the tractor must be stopped - the clutch must be depressed.
/ Down shifting #5
Disclosure: I have no TYM433 experience. And I don't know your experience with manual transmissions, so don't be insulted.
:2cents: As per tractordata.com: "Four synchronized gears (1-4) in four ranges with synchronized shuttle shift. Tractor must be stopped to shift range."
I assume you're talking about the gears 1-4, not the ranges? These should be synchronized, so stopping shouldn't be necessary.
That being said, try some "old school" shifting like one has to do when a transmission doesn't have synchronous gears:
Typically when one upshifts it's easier because you typically back off the throttle (yes?), shift up, and now the lower engine rpm in higher gear nearly matches your existing ground speed = smooth shift.
On the downshift you have to make it do the opposite: Lower engine rpm in higher gear prior to shifting, clutch in, shift lever to neutral, rev the engine UP to match (or slightly above) the engine rpm that will be required to match your ground speed in the lower gear, then shift into lower gear, release clutch.
Better yet, double clutch it: Same as above, but after clutching and bringing shift lever into a neutral spot, release clutch when in neutral, rev. engine up to match (or slightly above) the future lower gear's corresponding engine rpm (at your present ground speed), then clutch in again, place in lower gear, release clutch. All of this can be done so total shift time is about <1 second. :D
Edit: I should clarify that when I say "rev engine up", I mean bump it up and release, don't hold rpms there. You're looking to find that one special engine rpm that corresponds to ground speed in future gear where transmission will go in smoothly. Because you don't know exactly what that rpm is, by bumping and letting off, you can "find it" as engine spins down.
It's easier to do than explain!
...and like the saying goes:
IF YOU CAN'T FIND IT, GRIND IT!" - No, not really, don't do that!
/ Down shifting
Yep I’m meaning the 1-4 gears not the ranges. It’s not the biggest headache. The only times I really wish I had it is the once or twice I pull the kids through the neighborhood and it’d be nice to just downshift at the turns rather completely stopping. I don’t know if my clutch needed adjusting or what bc I don’t think it’s ever down shifted- just grinds. I’ve tried the double clutch and I could be doing it wrong with not having that sweet spot found yet but I just rather stop than hearing my gears grind. It’ll shift forward/reverse fine while still rolling so I assume my clutch is disengaging fine.
Thank y’all for the input I was curious if I’m the only one.
CAT 621B Transmission (A68134)
CAT 621B...
3pt Vicon Fertilizer Spreader (A64912)
3pt Vicon...
Giyi Mini Excavator Attachment Set (A64912)
Giyi Mini...
2019 Toyota Camry Hybrid Sedan (A66738)
2019 Toyota Camry...
2018 MACK CXU (PINNACLE) (A67714)
2018 MACK CXU...
2022 Landmaster EV (A64912)
2022 Landmaster EV...
