Door opener problem
/ Door opener problem #41
FYI: When you use a jackshaft operator there is no bar pushing on the top of the door when closed. This can cause a very large gap between the door and the door frame at the top which is difficult to adjust. Not a problem for unheated buildings unless small critters decide to move in.
On all my doors, the top rollers on each side can be adjusted to eliminate this gap.
/ Door opener problem #42
My problem was with a 16 foot wide door where the ends shut OK but the centre was open. This could be adjusted with a brace across the top but the adjustment changes with the temperature.
/ Door opener problem #43
Not sure of the model you have but some models have an issue with the timing module.
/ Door opener problem #44
My 10' doors also have some flex, so the center can have a gap but the sides are snug. I added a section of angle iron to stiffen the top edge.
It doesn't have to cover the entire door width. An 8' section works on my 10' doors.
The flexible vinyl molding around the door edge seals any remaining open space and allows for temperature changes.
/ Door opener problem #45
Most openers will bypass an eye, but you have to hold down the button. This is to be able to close a door with defective eye, until eye can be replaced. Its done this on my genie, chamberlin and old sears closer.
This is why I read so many of the different posts on this forum. I did not know that holding the wired button down would bypass the electric eye. I immediately verified it on my door opener. I am smarter than when I woke up this morning.
Doug in SW IA
/ Door opener problem #46
some info for ya Dodge:
If your Chamberlain 1/2 HP garage door opener remote isn't closing the door, the most likely culprits are: dead batteries in the remote, misaligned safety sensors, a faulty remote needing reprogramming, or a problem with the motor unit itself; check the sensor alignment, replace the remote batteries, and try reprogramming the remote to the opener if necessary.
Common problems with a Chamberlain 1/2 HP garage door opener include: issues with the remote control (low battery, not programmed), faulty safety sensors misalignment, motor problems (overheating, worn out), power supply issues (circuit breaker tripped), damaged wires, incorrect door limit settings, and a malfunctioning control board; if your door won't open or close fully, check for obstructions in the track or potential issues with the door springs as well.
willy
/ Door opener problem #47
If you give up, Amazon has the belt drive with battery backup on sale for 177.63. The app is handy, I'll open the garage in the morning in the summer to cool it off from inside.
Limited-time deal: CHAMBERLAIN B2215T Garage Door Opener with Battery Backup, Black Amazon.com
/ Door opener problem #48
I think the op already replaced his opener a few posts back.
/ Door opener problem #49
I like my new chamberlain units. I got the slightly upgraded unit from lowes. It has a smart indoor button with motion lights. Now when i open door at night to go into garage, the opener lights come on by themselves. I also use the wifi function when snowblowing in winter. I can open the doors from tractor to prevent damage, and dont have to leave an opener control inside the tractor. I also have mine set to close automatically at 8pm in case we left the door open.
/ Door opener problem #50
Just built a house with attached garage. 3 big, heavy garage, doors. 2 of them are
16’ high. I too wanted the jackshaft openers. They delivered tee bar units. I was ticked off as I already installed all the wiring for the jackshaft units. They subsequently sent me one jackshaft unit which I installed on one of the smaller doors. The door distributer came out to the building site to discuss the mix up. Now understand, they supplied the doors and openers. The rep took one look at the door that had the jackshaft opener installed and stated that this opener is not rated for the door and in fact a safety issue. I asked him to explain. Since the jackshaft is directly tied to the torsion shaft, if one or both cables break, that doors is coming down. That got my attention, as these doors are in excess of 700lbs! With a tee bar unit, you lose a cable, the tee bar attachment is going to hold the door in place, probably cocked in the track, but not drop to the floor. Needless to say, I installed three tee bar units on these doors. A pain in the but as my garage walls are 19’ tall and I am not a fan of heights.
I got a new opener sitting in a box in the garage, I just have to install it. I’m 99% sure it’s the board in the opener.
/ Door opener problem #52
I just went thru this with one of my three 25yo Genie screw drive openers. Bad receiver in the control board like you seem to have. I considered a replacement external receiver, as others posted, but my new opener only cost a bit more. Can't find a replacement OEM receiver.
Here in CA, we are forced to buy battery-backup units now, so that's what I got. I always wanted to try one of the new quiet belt drive units anyway.
Wow, is it quiet. DC motor with electronic controls and motion detector light. Electronic adjustments for position and pressure. No WIFI in my new $100 Genie 1155.
Mechanically-speaking, the screw drives seem superior in that they always stay lubed, and don't have a sprocket or chain/belt to wear out. The noise issue may be due to the old AC motor, tho I recently became single, so it does not really matter any more.
The battery already got tested, as I had a couple of power outages already. It is lead-acid, but is always on a built-in trickle charger.
/ Door opener problem #53
My entire house is battery-backed up, and there's no car in the garage regardless. Would I still have to buy a battery unit? Is that actually a law in CA?
/ Door opener problem #54
Ya, my house is whole house backuped, so none of my 5 openers are battery backup units. Not required here
/ Door opener problem #55
Yeah, someone in the recent wildfire in Paradise, CA died as a result of being caught inside his/her garage when the power was off. Burned up. No one knows why he/she didn't just pull the release cord or drive thru the door.
Now, no retailer will sell you an opener without battery B/U, or ship to you in CA. Just go pick up a 49-state version at the Home Depot next time you are in Reno.
/ Door opener problem #56
Some jackshaft openers have a safety brake to prevent rapid door closures from spring or cable breaks. They are usually the higher priced commercial units though.
It should also be noted that most failures on newer garage doors involve a broken torsion spring. When that happens, whether it's a T bar or jackshaft opener, that door is coming down. The cables are fairly easy to inspect and most worn or frayed spots are easy to spot. Not so with the springs. They can let go with no warning at all.
I have 5, 10 x 10 overhead doors and have never seen a cable failure in 40 years of operation. I've had 2 springs break though, one almost got the wife when the door came down.
The older, twin spring along the track design was better at preventing rapid door drops since both springs rarely broke at once. They have been mostly phased out though, since a spring break with that design could take out a wall or a piece of you.
Unfortunately, most of us tend to take our overhead doors for granted. They are mechanisms with a great deal of stored energy, capable of causing severe injury. They should be treated as such and inspected regularly.
/ Door opener problem #57
I have the twin springs still, with safety cables that run through the spring.
Had a spring break, spring stayed on the cable and no damage.
Door was down at the time, a little hard to get back up, but spring replacement was easy.
Have replaced both springs on that door. No more problems.
/ Door opener problem #58
All three of my 8x7 Clopay doors have the side springs with safety cables, but my older workshop 8x8 door has torsion springs.
I also had a side spring fail 40+ years ago in a different house with a 7x16 wooden sectional door. The safety cable broke, too. I came out to the garage one day and there is was in pieces. No damage.
One thing most of us neglect is lubrication of all the rollers and hinges. I use an aerosol spray grease.
I ordered a new Chamberlain opener and all the parts were identical so I just installed the box with the motor in it. The installation was easy, getting it to work wasn’t. It didn’t come with an installation manual but I found it on line. Then the users manual was for just about every unit they make and the procedure for setting the up and down limits was wrong. I found the correct manual on line and got it going. Now I just have to get the wife’s Chrysler 300 programmed to it, that’s not going so good.
I assumed this was made in China but it’s not, either Illinois or Mexico. All would have been good if it had the correct manuals with it.
/ Door opener problem #60
Sorry to hear that the new unit is being so difficult and I agree it should have come with the correct instructions! You're intuitive though and I know you'll get it figured out. Best of luck.
