Do I need a new auger tip?
/ Do I need a new auger tip? #1
ugabulldog
GA
'04 MF 451 diesel shuttle shift w/ MF 1040 loader
Just replaced blades, does tip look like it needs replacing? Has hard time digging a hole but ground is VERY dry now also. Thanks
/ Do I need a new auger tip? #2
Yes you do.
/ Do I need a new auger tip? #4
Yes that is pretty worn. Once you fix it add some weight if you can to the digger it will help immensely. When I had a 3pt digger I welded a couple hundred pounds on it.
ok, thanks, .....I should have been more specific, I need the whole point assembly, not just the very tip that connects with roll pin, ?
/ Do I need a new auger tip? #6
Georgia clay is hard diggng when you have not had rain for 2 months. Hopefully you are getting some but I doubt that the ground will soften up anymore than a few inches
/ Do I need a new auger tip? #7
You need whatever it takes to get a new lead screw on the bottom. Not sure from the pic how that attaches, clearly different from mine.
County Line 3Pt Chisel (A66408)
County Line 3Pt...
Kubota SVL 75-2 Skid Steer (A65579)
Kubota SVL 75-2...
2022 EZ-GO ELITE...
2004 International 4300 Box Truck, VIN # 1HTMMAAMX4H667102 (A65563)
2004 International...
1/4" Quick Attach Blank Plate (A66408)
1/4" Quick Attach...
2001 UNKOWN  GOOSENECK PUMP TRAILIER (A65643)
2001 UNKOWN...
