Do I need a new auger tip?
/ Do I need a new auger tip? #1
ugabulldog
GA
'04 MF 451 diesel shuttle shift w/ MF 1040 loader
Just replaced blades, does tip look like it needs replacing? Has hard time digging a hole but ground is VERY dry now also. Thanks
/ Do I need a new auger tip? #2
Yes you do.
/ Do I need a new auger tip? #4
Yes that is pretty worn. Once you fix it add some weight if you can to the digger it will help immensely. When I had a 3pt digger I welded a couple hundred pounds on it.
ok, thanks, .....I should have been more specific, I need the whole point assembly, not just the very tip that connects with roll pin, ?
/ Do I need a new auger tip? #6
Georgia clay is hard diggng when you have not had rain for 2 months. Hopefully you are getting some but I doubt that the ground will soften up anymore than a few inches
/ Do I need a new auger tip? #7
You need whatever it takes to get a new lead screw on the bottom. Not sure from the pic how that attaches, clearly different from mine.
PRIEFERT PORTABLE CATTLE SQUEEZE CHUTE (A64277)
PRIEFERT PORTABLE...
2016 Freightliner Cascadia 125 T/A Day Cab Truck Tractor (A61573)
2016 Freightliner...
2016 Kubota RTV X1140 (A65563)
2016 Kubota RTV...
Massey Ferguson 285 Loader Tractor (A66285)
Massey Ferguson...
2016 FORD E450 SHUTTLE BUS (A59914)
2016 FORD E450...
2006 Kenworth T800 Tandem Dump Truck, VIN # 1NKDLU0X26J147788 (A65563)
2006 Kenworth T800...
