Do I need a new auger tip?
/ Do I need a new auger tip? #1
ugabulldog
GA
'04 MF 451 diesel shuttle shift w/ MF 1040 loader
Just replaced blades, does tip look like it needs replacing? Has hard time digging a hole but ground is VERY dry now also. Thanks
/ Do I need a new auger tip? #2
Yes you do.
/ Do I need a new auger tip? #4
Yes that is pretty worn. Once you fix it add some weight if you can to the digger it will help immensely. When I had a 3pt digger I welded a couple hundred pounds on it.
ok, thanks, .....I should have been more specific, I need the whole point assembly, not just the very tip that connects with roll pin, ?
/ Do I need a new auger tip? #6
Georgia clay is hard diggng when you have not had rain for 2 months. Hopefully you are getting some but I doubt that the ground will soften up anymore than a few inches
/ Do I need a new auger tip? #7
You need whatever it takes to get a new lead screw on the bottom. Not sure from the pic how that attaches, clearly different from mine.
New/Unused AGROTK 72in Quick Attach Brush Cutter (A65583)
New/Unused AGROTK...
Fire Ring (A65640)
Fire Ring (A65640)
2011 Nissan Murano SUV (A61574)
2011 Nissan Murano...
Cattle Feeder (A65640)
(4) HD Pipe Gates (A66408)
(4) HD Pipe Gates...
3 Bottom Plow (A65640)
