Do I need a new auger tip?
/ Do I need a new auger tip? #1
ugabulldog
GA
'04 MF 451 diesel shuttle shift w/ MF 1040 loader
Just replaced blades, does tip look like it needs replacing? Has hard time digging a hole but ground is VERY dry now also. Thanks
/ Do I need a new auger tip? #2
Yes you do.
/ Do I need a new auger tip? #4
Yes that is pretty worn. Once you fix it add some weight if you can to the digger it will help immensely. When I had a 3pt digger I welded a couple hundred pounds on it.
ok, thanks, .....I should have been more specific, I need the whole point assembly, not just the very tip that connects with roll pin, ?
/ Do I need a new auger tip? #6
Georgia clay is hard diggng when you have not had rain for 2 months. Hopefully you are getting some but I doubt that the ground will soften up anymore than a few inches
/ Do I need a new auger tip? #7
You need whatever it takes to get a new lead screw on the bottom. Not sure from the pic how that attaches, clearly different from mine.
CATERPILLAR 259D SKID STEER (A64279)
CATERPILLAR 259D...
2022 CATERPILLAR 272D3 SKID STEER (A65053)
2022 CATERPILLAR...
2019 KOMATSU D65PXI-18 CRAWLER DOZER (A65053)
2019 KOMATSU...
2019 GMC SIERRA HD 3500 (A63569)
2019 GMC SIERRA HD...
2019 FORD F-150 STX CREW CAB TRUCK (A63276)
2019 FORD F-150...
2024 Kubota RTVXG850GLAS24-A Sidekick Utility Vehicle - 19 hours
2024 Kubota...
