4570Man
Super Star Member
- Joined
- Apr 7, 2015
- Messages
- 19,046
- Location
- Crossville, TN
- Tractor
- Kubota M59, Kubota L3800, Grasshopper 428D, Topkick dump truck, 3500 dump truck, 10 ton trailer, more lighter trailers.
My dump truck has been plagued with starting issues since before I’ve had it. The batteries load test good, the connections are tight and corrosion free. The starter sometimes just clicks. Usually if you click it a few times it’ll engage and start. Otherwise times it won’t engage and I usually roll it off. Other times if I’m not on enough hill to successfully roll it off, but turn the engine a little the starter will then engage. When it does turn over at a normal speed. It has a new starter on it. When I put the starter on I didn’t think to roll the flywheel over to inspect the whole thing, but the bottom looked good. The problem is worse when the truck is hot. It used to be 100% start the when the engine had several hours or more to cool, but it’s becoming more random, and I’ve been unable to run down the problem. Due to the problem I idle the truck a lot. I changed the oil tonight and it seemed to have diesel in it. I don’t have any lab equipment or oil annals so the best I have to work with is smelling it. I contribute that problem mostly to idling it a lot so I need to fix the problem.
