DK5310SE Irregular Chirping Sound From Power Steering Unit
   / DK5310SE Irregular Chirping Sound From Power Steering Unit #21
Thanks for the information, Venturabrass. Was it you that said you have a manual? If so, where did you purchase it? I would presume the manual for the DK 4510SE HST should be good for the DK 4720SE HST. THANKS
Yes I have the manual. I bought it from the dealer the day I bought the tractor. It covers the DK10SE series. I’d think it’d be almost identical to the DK20SE as all that really changed was loader joystick, led headlights
   / DK5310SE Irregular Chirping Sound From Power Steering Unit #23
What specific hydraulic fluid did you use at the 50 hour change?
Mobile 424, but others have used Shell, Kioti, and the usual other brands and have said the odd noise persists. This topic has come up a few times in that fb group.
   / DK5310SE Irregular Chirping Sound From Power Steering Unit #24
Well had a little bit of time before we bugged out for vacation today. Ironically the tractor really wasn’t making the sound for the first 20 minutes and then started to towards the end. I can confirm I did not hear any sound or feel any vibration coming from the hydraulic pump. All of this was focused at the steering unit, I’m now realizing this is called an orbitrol valve.
When it was happening I tried turning the steering wheel both ways. It did not change the sound even though I was technically changing the fluid flow path internally. There was also no chattering of the steering or any other function for that matter. All hydraulic functions were smooth as silk.
I caught up watching some videos of what hydraulic cavitation is. It seems like it’s more of a continuous sound. And becomes louder the worst the condition is. Not really a random “chirp chirp”.
Changing engine rpm sometimes changed the sound or intensity. But otherwise occurrence seemed completely random.
Yeah we are definitely talking about the same thing. I had a video awhile back that you can clearly hear that sound. I'll see if I can find it.
Edit: Found the video I made, but it won't upload on here due to improper formatting.
   / DK5310SE Irregular Chirping Sound From Power Steering Unit #25
Venturabass, I’ll have to buy one. And, yes… just minor changes between models.
   / DK5310SE Irregular Chirping Sound From Power Steering Unit #26
Thanks KiotiKyle
   / DK5310SE Irregular Chirping Sound From Power Steering Unit #27
I’m still wondering if this sound is resonating from a vibration somewhere or if it is actually hydraulic related.
I haven’t started the tractor today, but suspect it only happens when it reaches operating temperature… after it warms up.
I need to study the manual when I’m back home. Was looking up info on cavitation, but it seems like it’s generally on the low pressure side of pump. Would make you think well how do you have cavitation on the pressure side? Though these pumps only build pressure when there’s a resistance to flow or you’re counteracting lifting a load. And what’s the deal with this modulator valve we have? I think I remember it’s just upstream of the steering unit?
   / DK5310SE Irregular Chirping Sound From Power Steering Unit #29
My noise got a little louder and I Just discovered a hydraulic leak on the right side, behind the rear tire where linkage enters the transmission. All this at 6hrs on the meter And very light duty work.
I scheduled a warranty service appointment, but it’s two weeks out. Depending on the diagnosis, I may just request that Kioti replace this tractor with a new one. This one is a Lemon... and I’m willing to go through arbitration.
I really wanted to like this tractor, but I’m now very skeptical about its durability. I should have just paid the extra 10k for the JD. I’m wondering if Kioti is buying Chinese parts now…
Sorry to hear gumshu. No one wants issues after spending all this money.
If it’s helpful check “bolt1” in the diagram and photo. This is a cap that goes on rear remote valve, where you’d stack a second valve. I had a leak on mine and dealer found one of the bolts was loose. There’s like 4 orings behind it so be careful if you take off. Won’t cure frustration but will keep you going if this is it.
   / DK5310SE Irregular Chirping Sound From Power Steering Unit #31
Ventuarbass, thanks for that. I’ll have to take a closer look. At first glance it appears to be coming from where the linkage enters the transmission As the fluid is dripping down the linkage. Perhaps it’s coming from above it. it would be nice if all these issues were a simple fix, as I’ve lost confidence in Kioti. I never heard back from them after submitting a contact request online And service people are no help over the phone.
I have to wait two weeks to get it in for warranty service. The closest dealer to me is 1 1/2 hrs away. The original dealer is 3 hrs away. I’m going to have the dealer look at all the issues. I’m so frustrated that I may even sell this machine once It’s serviced. I’ve never had so many issues with any of my other tractors… even after hundreds of hours.
   / DK5310SE Irregular Chirping Sound From Power Steering Unit #32
I checked this morning and those bolts on your pictures are dry. The leak is below the bolts where the linkage is connected to the trans housing. I was hoping I was wrong and it would be as simple as tightening a bolt. It’s a drip drip. Thanks again.
   / DK5310SE Irregular Chirping Sound From Power Steering Unit #33
Here's what someone just posted this morning in the Kioti fb group:
"Just an update from posts from approx 1 year ago regarding DK models with hydraulic pump cavitation, there is a service bulletin for this, its called “DK hydraulic pump noise reduction kit”. I had this repair done at my dealer and it stopped about 90% of the problem. My machine after completely warmed up, the noise is very faint, you really have to have a ear for it to notice. The repair takes approx 1 hr and involves replacing a hydraulic return hose."
   / DK5310SE Irregular Chirping Sound From Power Steering Unit #34
Thanks for the information, Kyle.
   / DK5310SE Irregular Chirping Sound From Power Steering Unit #35
I’m surprised that they posted a service bulletin a year ago that they are still manufacturing units with the same problem.
   / DK5310SE Irregular Chirping Sound From Power Steering Unit #36
I dropped off the tractor for warranty service involving a number of issues At only 6 hrs on the meter.. I spoke with the service tech today who said the noise in the steering hydraulics was due to a defective O-Ring in the hydraulic pump Which was allowing air to enter the system (cavitation). According to him, it is supposedly fixed. I should have it back-in a few days and should know more.
For those of you who have this problem, you may want to have your service tech contact Mario at Valley Implement, Preston, Idaho.
   / DK5310SE Irregular Chirping Sound From Power Steering Unit #37
Have a DK5310SE I bought in spring 2022. Since new I’ve always noticed an irregular chirping sound of sorts. Doesn’t always happen. Sometimes will happen a lot. Sometimes not as much. Sometimes it’ll happen right at startup at idle and other times only when I run the rpms up to go do work.
The pattern is really irregular. “Chirp, chirp….chirp… chirp, chirp….”. I’ve talked to the dealer about it and they told me they hear this sound often from new. Kioti knows about it. But there is no fix or any history of there being a problem.
One day when it was happening I tried hard to locate where it was coming from. It’s not the engine. It turned out it’s coming from the power steering unit just below the steering wheel. I took the cover off and each time it happens I can feel a mild vibration. But there are no loose external parts. Also operating the steering wheel does not cause it and never has. It happens just sitting still.
Anyone hear this on their machine and anyone know what it is?
Same noise hear on a dk 4210. Did u ever get to the bottom of it or is it considered normal for the dk’s? Talked to the dealer and they said they had no noise complaints from customers.
Hey Cedar Fields. So I've been researching this a lot and think I finally have it all figured out. Thanks to Kioti Kyle on here that tipped me off to Facebook. If you search for the group "Kioti Tractors Group" on Facebook, request an invitation to be added. The search for posts containing "DK Pump Noise". There's a couple posts by gentleman named Curt and Mike on there that discuss the same problems. Curt shows photos of what his dealer found and how to fix it.
Apparently the 3 point lift valve in the case under your seat has an issue with the size of the return port (or bad casting?) and the hydraulic fluid "jets" out of it. When this happens it aerates the oil on it's way back to sump. Then as you're operating that aerated fluid goes through the pump and causes noise in the orbitrol steering valve. I was a little puzzled by this at first because the pump does not make any noise, and why wouldn't I have symptoms of air on the primary circuit? Well I paid closer attention and I do. If I run at operating speed for awhile and get it good an "aerated", and then operate the front end loader by lifting it, I can feel faint hesitations when it lifts as air is interrupting the lift. No noise though.
I have two dealers - the one I bought my machine from and the one that's closest to me. The closer has only been selling for Kioti's for a few years. They seem to have a lot of mechanical experience but have always told me they don't have any history of this noise (BS). The dealer I bought from is aware and so is the regional Kioti rep, but Kioti doesn't really have a fix for it. There is a service bulletin out there, but I later found it's not well known at the Kioti dealership level. The bulletin is just a Powerpoint doc (no bulletin #). It shows disconnecting the hose from the secondary side of the pump that goes to the steering valve, and adding an extra 8' of hose to the circuit to increase the volume. The folks on the Kioti Facebook group seem to say it has helped but not eliminate. I think this is a cheap way out for Kioti to try to solve some noise without solving the root cause. And my dealer wasn't super clear if this was covered under warranty because it's hit or miss if it works. I think the idea is having more fluid ahead of the valve maybe adds time for the air to disperse? Maybe break up into smaller bubbles that pass with less noise?
What is supposedly fixed it for one gentleman on Facebook was his dealer fabricated a piece of bent sheet metal that acts to diffuse the fluid to prevent all that turbulence that's causing the aeration as it drains to tank. He says it fixed all his problems. I showed my dealer this post, as they're rather interested in finding a fix for their customers. They shared with the Kioti rep and their response was "it was not an approved Kioti repair and wouldn't fix the problem". Frustrating as hell.
I also got some feedback that Kioti may have lost the casting design at one point in the production run, and had to re-create it, which may have resulted in this problem. And from I understand with the new DK20SE series (DK4220SE, etc) so far they haven't seen the problem.
If you search hydraulic aeration on Youtube, it's not good for the machine. Though with the pumps not making noise it's hard to tell if this will be a long term problem or not. Both dealers seem to tell me they have not had a hydraulic failure due to this specific issue. This model series came out in 2018. Unsure if all years up to the DK20SEs have the problem though. So if a failure does happen, guarantee it's after warranty.
I'm currently looking into a way to make a baffle plate, but I'm also going to have my dealer try to pull up part numbers for the 3 point lift valve I have and the ones on the DK20SE series. Interested if it's the same part #. Betting it's interchangeable. Probably several hundred dollars. Why should I have to pay for it though!
   / DK5310SE Irregular Chirping Sound From Power Steering Unit #39
Cavitation isn't good for any pump.
2015 LOAD TRAIL 24+6 GOOSENECK TRAILER (A58214)
2015 LOAD TRAIL...
WINCH CABLE DRUM (A58214)
WINCH CABLE DRUM...
Unused 2025 CFG Industrial QH12R Mini Excavator (A59228)
Unused 2025 CFG...
KNOW BEFORE YOU BID - DO YOUR HOMEWORK AND BE HAPPY WITH YOUR PURCHASE (A60432)
KNOW BEFORE YOU...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
2018 CASE 340RT TRACKED TRACTOR (A60430)
2018 CASE 340RT...
