DK5310SE Irregular Chirping Sound From Power Steering Unit
   / DK5310SE Irregular Chirping Sound From Power Steering Unit #11
I know these are low hour tractor’s, that are being discussed, but it would be interesting to see if the noise is diminished/eliminated when the fluid is changed out. If so, how many hours on the fresh oil before the noise returns….? 🤷
Unfortunately swapping out fluid is an expensive endeavor….not going to be my first choice. Should be the anything wrong with Kioti fluid from the factory.
I’m headed out on vacation but this thread has inspired me to take a closer look at things. When I get back I’m going to try to see if I have vibration or noise at the pump, or if it’s just at the power steering unit.
One thing I can say is I’ve never experienced any jerking in the steering due to cavitation.
   / DK5310SE Irregular Chirping Sound From Power Steering Unit #13
I can answer that with unfortunately not. I changed my hydraulic fluid at 50 hrs and then had to change it again due to a major hose pinch where almost all of my fluid leaked out (awful...). The noise continues after both fluid changes, and I've heard others say the same.
   / DK5310SE Irregular Chirping Sound From Power Steering Unit #14
I just purchased this DK 4720 last week with .08 hrs. When I called the dealer about my jerky 3pt hitch, he said it could be air in the system… only one hour on the meter. We’ll, how did the air get there. Cavitation crossed my mind when this noise developed in the steering area as air in the system could travel to other areas. Air in the system does create noises and erratic behavior and I have both. Cavitation creates problems. I contacted Kioti via their website and waiting to hear back. I hope they’re not ignoring a faulty pump issue… if that is the problem.
Another thought that crossed my mind is replacing the hydraulic fluid with Shell HD or Mobil 424 with the thought that water may have gotten into the system at some point during storage or perhaps someone used the wrong fluid during assembly.
Does anyone here have a jerky 3pt hitch when trying to raise it SLOWLY? It’s not a problem raising it quickly. I’ve never encountered this issue on my other tractors.
Has anyone here seen an improvement or elimination of the noise in the steering area after replacing the hydraulic fluid?
   / DK5310SE Irregular Chirping Sound From Power Steering Unit #15
Apparently, people were answering the hydraulic fluid change as I was asking the question 😀
   / DK5310SE Irregular Chirping Sound From Power Steering Unit #16
What specific hydraulic fluid did you use at the 50 hour change?
   / DK5310SE Irregular Chirping Sound From Power Steering Unit #17
A little bit of moisture wouldn’t hurt the function, unless the moisture is so much that it’s clearly visible in the oil. Good time to do a used oil analysis…😉
   / DK5310SE Irregular Chirping Sound From Power Steering Unit #18
Thanks Robin. Someone mentioned that the oil change didn’t solve the noise issue. So that’s off the table for now. Waiting to hear from Kioti before I make the 3 hr drive to the dealer. Typical dealer responses these days indicate they don’t have a clue or aren’t interested in fixing a problem. I just want to start a warranty claim in the event the issue gets worse and they then deny warranty service.
Well had a little bit of time before we bugged out for vacation today. Ironically the tractor really wasn’t making the sound for the first 20 minutes and then started to towards the end. I can confirm I did not hear any sound or feel any vibration coming from the hydraulic pump. All of this was focused at the steering unit, I’m now realizing this is called an orbitrol valve.
When it was happening I tried turning the steering wheel both ways. It did not change the sound even though I was technically changing the fluid flow path internally. There was also no chattering of the steering or any other function for that matter. All hydraulic functions were smooth as silk.
I caught up watching some videos of what hydraulic cavitation is. It seems like it’s more of a continuous sound. And becomes louder the worst the condition is. Not really a random “chirp chirp”.
Changing engine rpm sometimes changed the sound or intensity. But otherwise occurrence seemed completely random.
Gumshu, on your chattering 3ph check out this video on some reasons this can happen.
This has happened before on mine but isn’t frequent. I know we’re both having the steering unit issue but the hydraulics for the 3ph come from the main pump circuit not the secondary pump which feeds the steering.
2015 VOLVO L110H WHEEL LOADER (A60429)
2015 VOLVO L110H...
Hays LT-1 Tender (A56438)
Hays LT-1 Tender...
(INOP) 2016 CATERPILLAR 259D SKID STEER (A52709)
(INOP) 2016...
Year: 2017 Make: Ford Model: Fusion Vehicle Type: Passenger Car Mileage: 101,691 Plate: Body Type... (A55853)
Year: 2017 Make...
40 (A52708)
40 (A52708)
2016 FREIGHTLINER CASCADIA TANDEM AXL MID ROOF SLEEPER TRUCK (A59905)
2016 FREIGHTLINER...
