Power-trac hydraulic questions
   / Power-trac hydraulic questions #1
davesisk
Platinum Member
Raleigh, NC USA
Massey-Ferguson MF 1220
Who can (and is willing) to describe a little about the hydraulic layouts in the Power-tracs? (I'm particularly interested in my older 1418 of course, if anyone has any knowledge...<g>) I'm hoping this thread will be educational for everyone, not just me!
In mine, there's apparently a gear-type pump on the front of the engine that's fed by the tank with filter in between. I gather than the wheel motors are driving by this pump, as well as a supply to a 2nd pump. There's a right/left throttle operated switch on pump #1 that (I'd guess) sends oil in the right direction to splitters for the wheel motors, then a line that goes to the presumably piston-type pump #2 mounted on the back of the engine. Pump #2 (according to Don at Power-trac) powers the steering cylinders, lift arms, and external hydraulic ports.
So, questions (somewhere between theory and practice, I guess).
1) Does anyone happen to have a layout that shows which lines run where?
2) Why is getting air into the lines such a bad thing? How does it damage the gear-type pumps, for instance? Will it also damage the piston-type pump? If so, why isn't it necessary to bleed lines feeding fluid out of the gear-type pump and into the piston-type pump? I'm assuming the gear-type pump feeds the piston-type pump since there's only one filter. Is this a correct assumption?
3) Why gear-type to drive the wheels, and piston-type to power cylinders? Are gears alway matched with hydraulic motors, and pistons always matched with cylinders? (I'm assuming that the front pump is indeed gear-type and the rear-pump is piston-type. They're certainly shaped differently...)
4) Are there any good books that talk about the types of hydraulic systems you find in these tractors?
Best regards!
Dave
   / Power-trac hydraulic questions #2
Here goes my best shot/w3tcompact/icons/smile.gif
1. Yes I have a layout. No, you can't have it/w3tcompact/icons/tongue.gif. This is because it is probably copyrighted by Power Trac and I don't want to get in trouble. However, I CAN tell you that the book has a great hydraulic diagram in it. You should be able to purchase one from Power Trac. Order it with some filters.
2. From what I gather air starves the pump of lubrication. That's all I know on that one.
3. The wheel pump is a variable volume pump. I don't think you can get that with a piston pump. <A target="_blank" HREF=http://www.tractorbynet.com/cgi-bin/compact/showflat.pl?Cat=&Board=genoperating&Number=99598&page=&view=&sb=&o=&vc=1> Click here to read a thread on HST and variable volume pumps</A>
4. <A target="_blank" HREF=http://www.adtdl.army.mil/cgi-bin/atdl.dll/fm/5-499/toc.htm>Click here for some good readin' on hydraulics for a starter </A>
Actually, I've ordered the manual for the 1418 from PT, but Don told me that it doesn't have a diagram of the hydrualics (since this machine is about 12 years old). Sure you don't have a JPG of that hydraulic diagram??? [G]
   / Power-trac hydraulic questions #4
I'm surprised that it is not the same as the PT400 series. I don't have it digitized, it is in the manual. Did they say it is different from the PT400 series?
Yup, Don said it's totally different from the new 400 series. However, what I was thinking was that if I could see how it works and is routed in a newer machine, then perhaps I could more easily figure this older machine.
I suppose I could just also order a manual for the 422, eh?
Regards,
Dave
   / Power-trac hydraulic questions #6
Well, sorry then. I guess I should have said that I have one for the 400 series. I didn't realize they made changes, although it doesn't surprise me. I'll look around some more and see what I can find /w3tcompact/icons/wink.gif.
