DIY valve adjustment
/ DIY valve adjustment #1
ryan08
Louisville KY
Kubota BX25 /Hustler 320
Anybody got a good DIY on a valve adjustment on a Kubota 3 cylinder. I have a 21.5 hp diesel in my Hustler Zero turn that has a lot of clatter and I have never adjusted the valves.
/ DIY valve adjustment #2
What do you mean "good DIY on a valve adjustment"?
I pretty much just removed a few hoses in the way, removed the glow plugs to make turning the engine easy, and removed the valve cover. It had a rubber gasket which my manual said was re-usable, but I bought a new one anyhow.
Took my measurements and made my adjustments on each valve where tehy were suppose to be measured.
Deano
A DIY is a walk-through the process.
Thanks for the link Randall
/ DIY valve adjustment #6
When (HR wise) is it recommended to check or adjust the valves on these engines?
/ DIY valve adjustment #7
I would go by the recommendations of the manufacturer.
On the D950 in my Hustler it is every 800 hours
/ DIY valve adjustment #9
Thank you for mentioning that you remove the glow plugs to relieve the compression. I know how to do valve adjustments, but I never did a diesel and no spark plugs to take out. I couldn't find them :)
Kubota L3901HST
Kubota L3901HST
2010 Sauber 25' Tag Trailer (A62613)
2010 Sauber 25'...
2017 Ford Escape 4WD SUV (A61569)
2017 Ford Escape...
Kubota M9960 Tractor (A61166)
Kubota M9960...
3PT 10' Rolling Cultivator (A60462)
3PT 10' Rolling...
UNUSED WOLVERINE MPF-11-2500G MINI PALLET FORKS (A62131)
UNUSED WOLVERINE...
