DIY valve adjustment
/ DIY valve adjustment #1
ryan08
Louisville KY
Kubota BX25 /Hustler 320
Anybody got a good DIY on a valve adjustment on a Kubota 3 cylinder. I have a 21.5 hp diesel in my Hustler Zero turn that has a lot of clatter and I have never adjusted the valves.
/ DIY valve adjustment #2
What do you mean "good DIY on a valve adjustment"?
I pretty much just removed a few hoses in the way, removed the glow plugs to make turning the engine easy, and removed the valve cover. It had a rubber gasket which my manual said was re-usable, but I bought a new one anyhow.
Took my measurements and made my adjustments on each valve where tehy were suppose to be measured.
Deano
A DIY is a walk-through the process.
Thanks for the link Randall
/ DIY valve adjustment #6
When (HR wise) is it recommended to check or adjust the valves on these engines?
/ DIY valve adjustment #7
I would go by the recommendations of the manufacturer.
On the D950 in my Hustler it is every 800 hours
/ DIY valve adjustment #9
Thank you for mentioning that you remove the glow plugs to relieve the compression. I know how to do valve adjustments, but I never did a diesel and no spark plugs to take out. I couldn't find them :)
Pallet of Anchor Shackles (A61166)
Pallet of Anchor...
New/Unused 5ft Quick Attach Mixer (A61166)
New/Unused 5ft...
UNUSED JCT 72" HYD TILLER (A62131)
UNUSED JCT 72" HYD...
New/Unused Wolverine 72in Quick Attach Brush Cutter (A61166)
New/Unused...
New Three Point Hitch Trailer Mover (A61166)
New Three Point...
2016 KENWORTH T880 TRI-AXLE DUMP TRUCK (A62130)
2016 KENWORTH T880...
