DIY valve adjustment
/ DIY valve adjustment #1
ryan08
Louisville KY
Kubota BX25 /Hustler 320
Anybody got a good DIY on a valve adjustment on a Kubota 3 cylinder. I have a 21.5 hp diesel in my Hustler Zero turn that has a lot of clatter and I have never adjusted the valves.
/ DIY valve adjustment #2
What do you mean "good DIY on a valve adjustment"?
I pretty much just removed a few hoses in the way, removed the glow plugs to make turning the engine easy, and removed the valve cover. It had a rubber gasket which my manual said was re-usable, but I bought a new one anyhow.
Took my measurements and made my adjustments on each valve where tehy were suppose to be measured.
Deano
A DIY is a walk-through the process.
Thanks for the link Randall
/ DIY valve adjustment #6
When (HR wise) is it recommended to check or adjust the valves on these engines?
/ DIY valve adjustment #7
I would go by the recommendations of the manufacturer.
On the D950 in my Hustler it is every 800 hours
/ DIY valve adjustment #9
Thank you for mentioning that you remove the glow plugs to relieve the compression. I know how to do valve adjustments, but I never did a diesel and no spark plugs to take out. I couldn't find them :)
1901 T/A CAR HAULER TRAILER (A59909)
1901 T/A CAR...
Towable Generator (A61567)
Towable Generator...
UNUSED WOLVERINE CCT-11-148V CONCRETE CHUTER (A62131)
UNUSED WOLVERINE...
2015 Jeep Wrangler Rubicon Vehicle (MPV), VIN # 1C4BJWFG8FL728783 (A61165)
2015 Jeep Wrangler...
UNUSED JCT HYD AUGER (A62131)
UNUSED JCT HYD...
Kubota M135GX Tractor (A61166)
Kubota M135GX...
