DIY valve adjustment
/ DIY valve adjustment #1
ryan08
Louisville KY
Kubota BX25 /Hustler 320
Anybody got a good DIY on a valve adjustment on a Kubota 3 cylinder. I have a 21.5 hp diesel in my Hustler Zero turn that has a lot of clatter and I have never adjusted the valves.
/ DIY valve adjustment #2
What do you mean "good DIY on a valve adjustment"?
I pretty much just removed a few hoses in the way, removed the glow plugs to make turning the engine easy, and removed the valve cover. It had a rubber gasket which my manual said was re-usable, but I bought a new one anyhow.
Took my measurements and made my adjustments on each valve where tehy were suppose to be measured.
Deano
A DIY is a walk-through the process.
Thanks for the link Randall
/ DIY valve adjustment #6
When (HR wise) is it recommended to check or adjust the valves on these engines?
/ DIY valve adjustment #7
I would go by the recommendations of the manufacturer.
On the D950 in my Hustler it is every 800 hours
/ DIY valve adjustment #9
Thank you for mentioning that you remove the glow plugs to relieve the compression. I know how to do valve adjustments, but I never did a diesel and no spark plugs to take out. I couldn't find them :)
2016 Toyota Camry Sedan (A61569)
2016 Toyota Camry...
2008 New Holland T2420 (A62177)
2008 New Holland...
(2) 460/85R38 TIRES W/8 LUG RIMS (A62130)
(2) 460/85R38...
2025 SDLANCH IRET13 Electric Tricycle (A60352)
2025 SDLANCH...
2014 Mercedes-Benz C300 Sedan (A61569)
2014 Mercedes-Benz...
2012 Sun Coast Trailers 712ESB5 S/A Enclosed Trailer (A61569)
2012 Sun Coast...
