DIY Mini Digger
/ DIY Mini Digger #91
Great work Colcreate. When you built rear bucket assembly you could have contacted me, I would be happy to help with geometry to achieve full 180 deg movement of the bucket without guessing the distances. For the outriggers I believe the folding type would give you great stability and compact design. Something like Huddig uses..
/ DIY Mini Digger
I've skimmed through the thread again but didn't see how big of a hydraulic motor you used for the drive. Do you remember how big it was? Also are you putting good power to your wheels? Do you think you could tow something heavy or are you just able to drive around?
The hydraulic motor is a 160cm3/rev and the overall gear reduction at the wheels is something like 12:1 in Low and 6:1 in high which in theory gives speeds of 3mph and 6mph. I have moved my 18ft boat trailer and also a tipper trailer with 1ton load around with ease over rough ground. The toughest task though is driving the front loader bucket into piles of dirt so low ratio only as it does struggle.
The tree stump shown in a earlier post weighed 880kg which was a ridiculous overload but it still managed to move it!
2008 CHEVROLET C8500 DUMP TRUCK (A59823)
2008 CHEVROLET...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A60430)
2006 TRAIL KING...
2003 IC Corporation 3000IC School Bus (A59230)
2003 IC...
UNUSED 2026 INDUSTRIAS AMERICA HYD TILT TRAILER (A60430)
UNUSED 2026...
2016 Troy-Bilt 18in. Push Mower (A60352)
2016 Troy-Bilt...
2007 STERLING L7500 TANDEM AXLE DUMP TRUCK (A59906)
2007 STERLING...
