DIY logging winch build
/ DIY logging winch build #61
Many places I log the trees are pointless to try to get without a winch,
/ DIY logging winch build #62
What does the winch do for you actually?
Not meaning to take anything away from your build, just asking.
You can think of a winch as a self storing 100'+ chain:D Also I imagine Dave is having a good time building it and he'll have even a better (pridefull) feeling using it.:thumbsup: Iirc, $300 is his projected budget.
I have to ask what could be a dumb question; is a logging winch really worthwhile for a non-professional who has a tractor?
I only manage a little patch of forest, and when I need to pull out a tree [several each year] I just chain it to the drawbar and drive. It seems to work just fine.
Ok, my trees aren't huge, my ground is flat, and I have 4wd.
First and foremost it allows you to get at trees that are off the beaten path, less impact using one road rather than driving around all through the forest.
And yes, I like building stuff and so far this is a fun project, I just hope it works as intended. My tractor is only two wheel drive and I can't (read don't dare) get it down over into some places it may not come up out of.
/ DIY logging winch build #64
but I mean, you could still attach a cable or chain up to where ever you would be winching from, and then instead of winching, drive forward; couldn't you?
I guess if you were anchored to another tree, you could have massive power, more than your traction would provide
/ DIY logging winch build #65
To do that you must have space, and having 60m cable to handle isent very practical.
/ DIY logging winch build #66
Who cares if you get any use out of it at all! It's the fun of the build and keeping to a budget.
/ DIY logging winch build #67
First and foremost it allows you to get at trees that are off the beaten path, less impact using one road rather than driving around all through the forest. .
Exactly, that is one of top reasons right there, off the beaten path winching a tree without moving tractor or winching a tree that is caught up in another tree, that really makes things easier.
In the past 45 years I've hauled out wood atleast a dozen different ways, a winch will take alot of the pull yank tug out of logging. For the past ten years I've used a pto winch on tractor to get out 7-8 cord firewood annually plus logs, so if I was only getting 2-3 cord of firewood a year I wouldn't bother buying a winch or tractor for matter, but at 5 cord + definitely as one gets older a cord of wood comes out harder, a pto winch just makes it easier in the long run.
So in the past 10 years from this $2,700,00 V3004 Fransgard winch, it's been 7X10=70 cord of firewood and around 12,000 board ft. of logs. Breakdowns are is 8mm cable, @ 100+ foot long, on my second one now. Winch drive chain broke once, had to get a link repair kit, that's it.
I like to keep it low impact. It's not my property and I don't want to mess up any more than I have to. Plus I'm too old to be dragging chains and cables :) If it was a field and I was cutting near the tree line then I would agree.
/ DIY logging winch build #70
You don't anchor the tractor to a tree, the winch anchors itself into the ground, so there's no strain on the tractor and it will pull a lot more than an average tractor can pull.
SR
Small update, my steel got delayed but should be here tomorrow. I ordered the last of the pieces (I think) I ordered a clutch disc from RokAuto for a 94 Dodge truck, 1500, 318 v8, it's 26 bucks and then I ordered an idler sprocket for the back side of the chain (I was debating using one or not) it was $8.08 from The Big Bearing Store :)
Once I get my 2x6x3/16 tube I will go to town on it. I was in town today and saw a buddies winch, I took some closeups of the brake, the mount and took some overall measurements. His drum is only about 5.5" wide but I think I am going to be OK with 8" drum. I was surprised to see how sharp of an angle the PTO shaft was with the winch in the air, I assume you aren't running it when the winch is lifted? I will have to remember not to. Oh that reminds me, I will have to buy a PTO shaft as I don't have one...lol
/ DIY logging winch build #72
Yes, the winch needs to be on the ground when winching. Looking forward to your end product!
/ DIY logging winch build #73
Surprise yup there is quite an angle on the dangle. I'm always pulling forward to get the next tree with pto engaged, the toplink can be adjusted to alleviate some of the pto shaft sharp angle, then once the last tree is hooked, usually 5-7 trees, I have the pto disengaged and off I go till I get stuck, then that's where a winch shines.
Now to be a better fabricator than me, try to make sure when things are tacked together it's right before welding, I always find out something wrong after it's welded. Since steel likes to move when welding on it and to keep something square-ish, a temp tacked steel brace will help immensely, or alot.
/ DIY logging winch build #74
I don't always have my winch on the ground when winching, it all depends on the load.
SR
/ DIY logging winch build #76
For 3 trees a year, it's not worth the investment. I heat with wood, and burn about 3 cords/year, plus pull out the occasional saw log. (I do not have a sawmill, but barter with a friend for his services.) Even at that rate, I could never convince myself it was worth the investment. When I went in on a neighborhood partnership on some forestland in my area, I finally made the leap to buy a logging winch. Having worked with it now for 7 or 8 years, I would definitely not be without it. Mine has 230 feet of cable (many winches have about 160', which is plenty for 99% of what I have done).
If you are clear-cutting (and on easy terrain), maybe you don't have much need for one, since you can drive right up to just about any tree you need. With the winch, I can drop trees in the forest and winch them trailside, rather than having to clear a path to each tree. I can pull trees out of places I could never go with my tractor. With a self-releasing snatch block, I can pull the trees around a corner. It's made a huge difference in my productivity in the woods.
For 3 trees a year, it's not worth the investment. I heat with wood, and burn about 3 cords/year, plus pull out the occasional saw log (I do not have a sawmill, but barter with a friend for his services. Even at that rate, I could never convince myself it was worth the investment. When I went in on a neighborhood partnership on some forestland in my area, I finally made the leap to buy a logging winch. Having worked with it now for 7 or 8 years, I would definitely not be without it. Mine has 230 feet of cable (many winches have about 160', which is plenty for 99% of what I have done).
Well said John. I see in your profile you have limb risers, I think that is a heck of an idea and once I get the front part of the cab back on I will probably add them. I have to build some ROPS and a top from the windshield frame to the ROPS.
/ DIY logging winch build #78
I use a long chain; only a third of your cable length though.
I have a chain hook on the drawbar, that hooks between links, so it's quick attaching at any length.
But yes, access is very easy, I rarely need the whole chain. I've cut down many trees in my little forest now not so much to make logging easier, but so I can get in there with my brush hog to cut the brush for fire safety.
Anyway, once it's on the chain, I pull the whole tree out into the open to cut it up, where I can then quickly push the cutoff limbs into a pile for safe burning during the wet season.
It's been 35 years since the last time I was in an American forest, but reading about how you all work, I remember how tangled it all is.
We're having an intense drought here in Portugal, a thrown butt could light my forest on fire.
THIS ENDS THE RUSSELL WISE ESTATE (A63291)
THIS ENDS THE...
2025 Hydraulic Brush Cutter Skid Steer Attachment (A61572)
2025 Hydraulic...
2257 (A64281)
2257 (A64281)
2023 Case TV620B (A64119)
2023 Case TV620B...
2019 Autocar Xpeditor Garbage Truck (A62613)
2019 Autocar...
2006 Generac SD0150 187kVA T/A Towable Diesel Generator (A61572)
2006 Generac...
