Backhoe ditch witch model 140 3pt backhoe
/ ditch witch model 140 3pt backhoe #1
johnierotten
I just picked up this ditch witch model 140 3pt backhoe but the seller didnt know which of the two ports in the block was supply and which was return for the hydraulic fluid.I havent found much info on this model hoe on the internet can anyone help? will I do damage to anything if hooked up wrong? Thanks for any help,John
/ ditch witch model 140 3pt backhoe #2
Welcome to TBN:D
You won't damage anything-but I would apply air pressure to one hose and make sure that it comes out of the other when all the valves are in neutral. You want to make sure the valve is an OPEN CENTER type.
If you post some pictures of the valve we may be able to identify the IN and OUT side for you.
Be very careful with this if it's only mounted to the 3PH...a lot of damage can be done to your machine from them since there is no subframe to distribute the load it will place on the machine.
What tractor are you attaching it to?
Hi ,I will try to get a picture on this evening,the hoe is going on a jd 4310, I plan on making up a sub frame after I look at some other tractors to see where and how they are attached. I will just take it easy with it untill it has a sub frame.Thanks for the help! J
/ ditch witch model 140 3pt backhoe #4
OK, be careful! You know that the tranny case is made of aluminum right?
No!!! I did not know it was aluminum.... Im stunned as I thought it would be steel or at least heavy cast. Now I will have to take it extra easy untill the sub frame is on. Thanks for the info! I will post a picture today of the ports , I appreciate your help. J
here is the photo of the supply and return ports,there are three hoses comming out of the bottom of the block ,there is a quick disconnect going to the two outside ports on the top of the block, and then the hose going to the center of the top of the block, Im stil unsure which is the supply and which is return. Any help would be great! thanks. J
If your sitting in the tractor seat there is one line going into the right side of the actual valve body and ther is two lines on the left. does this help at all?
/ ditch witch model 140 3pt backhoe #8
Sorry John, I missed your picture before...
I am not sure why here are three hoses...there are usually just two. I would "assume" the single line is the feed but I am just guessing on that. I am also not sure of the purpose of the block at the rear either.
Thanks for trying, I was able to get a hold of ditch witch and they gave me the info I needed. The supply was the one in the middle on top and the other two that were tied together were return. I hooked it up and all is good. I was able to pick up a subframe not for my tractor but I can make it work with some modifications. Now I just need to see where the correct mounting points for the subframe are so I can not be scared about using the hoe. Does anyone have any pictures of their sub frame on JD 4310? Thanks to Kenny all. :)
/ ditch witch model 140 3pt backhoe #10
Good news John-glad to hear you are making progress. You should start a new thread titled something like "4310 Backhoe Subframe" and see if you get more visibility from other members...
/ ditch witch model 140 3pt backhoe #12
I have a Ditch Witch 140 Backhoe that I mounted to a Bobcat 763 Skid Steer.There are 3 Hoses coming off the Ditch Witch.I am guessing that 2 hoses are a return line and can be connected together however I am not sure what line is the pressure line and which are the returns.I have included a photo of the hydraulic manifold on the Ditch Witch.Also I do not know what is the high pressure connection on the Bobcat.Top or Bottom.
Thanks
412 292 5183
2025 Unused SDLGC80 60v Electric Golf Cart (A64194)
2025 Unused...
1959 DODGE D510 DUALLY FLATBED TRUCK (A59823)
1959 DODGE D510...
Danuser 3pt Auger (A64119)
Danuser 3pt Auger...
2015 RAM 4500 HD 4x4 Service Truck (A62613)
2015 RAM 4500 HD...
2001 Sea Breeze RV (A62613)
2001 Sea Breeze RV...
2016 Kawasaki 62Z7 Articulated Wheel Loader (A61572)
2016 Kawasaki 62Z7...
