distributor woes
/ distributor woes #1
1st fws
Holden,La.
1955 800 ford utility 5 speed non live pto
installed new aftermarket distributor on 55 850 ford.won't start.
/ distributor woes #2
HMM?
6 volt or 12 volt??
Do you need a new rotor?
is the cap tight to the base?
Were the wire ends pushed all the way in to create contact?
Healthy spark?
good coil
Battery up to snuff?
/ distributor woes #5
The big question not answered, why did you replace the distributor? Did someone tell you it was bad? Now to the serious stuff, did you note the position of the rotor button before removing? Could the coil be bad? Have you tried rotating the distributor back and forth as the engine is being cranked?
2019 FORD F-250 SUPER DUTY (A65643)
2019 FORD F-250...
IRANCH IRGC40 ELECTRIC SCOOTER (A64280)
IRANCH IRGC40...
Gehl RS5-19 (A62177)
Valley Model 8000 Irrigation System (A62180)
Valley Model 8000...
12' x 76" Tilt Trailer (A66285)
12' x 76" Tilt...
1987 FORD F-350 CUSTOM SERVICE TRUCK (A64280)
1987 FORD F-350...
