distributor woes
/ distributor woes #1
1st fws
Holden,La.
1955 800 ford utility 5 speed non live pto
installed new aftermarket distributor on 55 850 ford.won't start.
/ distributor woes #2
HMM?
6 volt or 12 volt??
Do you need a new rotor?
is the cap tight to the base?
Were the wire ends pushed all the way in to create contact?
Healthy spark?
good coil
Battery up to snuff?
/ distributor woes #5
The big question not answered, why did you replace the distributor? Did someone tell you it was bad? Now to the serious stuff, did you note the position of the rotor button before removing? Could the coil be bad? Have you tried rotating the distributor back and forth as the engine is being cranked?
2015 Polaris Slingshot Motorcycle, VIN # 57XAASFAXF5104933 (A65563)
2015 Polaris...
Landhonor 8'x10' Galvanized Apex Metal Shed (A62679)
Landhonor 8'x10'...
2001 Belshe Backhoe Trailer (A64194)
2001 Belshe...
2014 Ram 2500 4x4 Crew Cab Pickup Truck (A64194)
2014 Ram 2500 4x4...
JLG TELESCOPIC FORKLIFT (A64279)
JLG TELESCOPIC...
excavator trenching bucket- one bucket per lot (A63689)
excavator...
