distributor woes
/ distributor woes #1
1st fws
Holden,La.
1955 800 ford utility 5 speed non live pto
installed new aftermarket distributor on 55 850 ford.won't start.
/ distributor woes #2
HMM?
6 volt or 12 volt??
Do you need a new rotor?
is the cap tight to the base?
Were the wire ends pushed all the way in to create contact?
Healthy spark?
good coil
Battery up to snuff?
/ distributor woes #5
The big question not answered, why did you replace the distributor? Did someone tell you it was bad? Now to the serious stuff, did you note the position of the rotor button before removing? Could the coil be bad? Have you tried rotating the distributor back and forth as the engine is being cranked?
Deutz F3L912 3-Cylinder Air-Cooled Diesel Engine - 48 HP - Industrial Pump Takeout (A63689)
Deutz F3L912...
2019 HYUNDAI V12530152-AJS 53' X 102" T/A VAN TRAILER (A59910)
2019 HYUNDAI...
2020 Takeuchi TL8R2 Track Loader with 72in Tooth Bucket (A63689)
2020 Takeuchi...
2015 Freightliner M2 106 AWD Altec AT37G 37ft. Insulated Bucket Truck (A60460)
2015 Freightliner...
2016 Ford F-350 Pickup Truck (A62613)
2016 Ford F-350...
2006 FORD F-150 XL TRITON EXT CAB TRUCK (A64276)
2006 FORD F-150 XL...
