Disaster down below
/ Disaster down below
I managed to move the sick Green Machine to a spot that will allow loading onto a trailer for a trip to the welding shop. I hooked a chain to the rear pin and ran it underneath to the lift arms. I hooked the chain around the welded cross piece and just used the joystick to lift the center of the machine. I used a piece of PVC pipe to operate the pedals and walked along side as it drove itself out.
Still waiting on the part from PT. So far, so good. /forums/images/graemlins/laugh.gif
/ Disaster down below #22
Hey, that's good news! Sounds pretty ingenious, too /forums/images/graemlins/cool.gif
/ Disaster down below #23
Great solution to get it to a trailer.
I doubt the replacement time is Terry's 10 min, but a welding shop should make pretty short work of it.
Back in business by the weekend?
I NEED to be back in business asap but I'm still waiting on the complete joint from PT. Unfortunatly in my business our weekend is the busy time and it starts on Friday. It will most likely be Monday before I get it fixed.
I can't belive how dependant I've become on the PT. We have a NH Boomer tractor w/ FEL, box blade, and Brush Hog, and a ZTR commercial mower, but the PT with all it's attachments has been the 'goto' guy for most projects. I try to keep the mower for mowing just the nice grass. The tractor is fine for heavy work but it's weight leaves ruts in our soft soil. The PT can do most tractor jobs and is turf and earth friendly. The little 4' bush hog is REALLY tough. I have nothing to backup it's auger, and we're really missing the extra mower this time of year. Maybe in another week this will all be over.
Thanks to all for your concern and helpful ideas.
Well the little green machine is back in business. We picked it up from the welding shop this afternoon. After about an hours time it appears to be working fine but I can detect some movement in the joint. I greased the new joint when I got it home but it may need some more. I'm using the machine but you can bet I'm being VERRRRY alert to anything out of the ordinary. Maybe I'm paranoid now but.........
/ Disaster down below #26
congradulations on your tractor being back in service /forums/images/graemlins/smile.gif
Daivd
/ Disaster down below #27
Rick,
I'm glad it's back in service for you. Any details from the welders on how the repair went. How does it look, good as new? Also interested in whether you can see any type of defect in the original heim joint where it failed.
Duane
The new weld could have been prettier but it seems to be holding. I need to order some touch-up paint from PT. There were two spots , one on either side of the old joint that appear to have been older cracks (see the picture attached to my original post). I'm wondering, does anyone else experience a shock or wham when the steering travel stops abruptly at full lock? I experience this when mowing around trees. I have also noticed a paint scrape on one side of the foward section, near where it would contact the steering cylinder at full lock.
I'm wondering about glueing some rubber bumpers onto the bang points where the front and rear sections come together at full lock. Those might absorb some of the shock and maybe prevent this from happinening again. You can bet I'm going to be much gentler turning from now on.
/ Disaster down below #29
Rick:
I have noticed a similar shock sometimes at full lock, and also have some contact marks on my 1845. You may be right that it's a contributer, but it sounds as if a weld problem led to cracks and weakening which shouldn't recur.
You'll get over babying it - Power Tracs just demand to be run hard, so as to outwork all the BX's out there.
(That should get a rise out of TresCrows /forums/images/graemlins/grin.gif)
/ Disaster down below #30
<font color="blue"> I have also noticed a paint scrape on one side of the foward section, near where it would contact the steering cylinder at full lock. </font>
Would it be possible to get a picture of that scrape area, so we soucl check it out on our machines? It would be much appreciated.
I haven't noticed any shock or bump when getting to the lock.
/ Disaster down below #31
Rick,
Ditto on the paint rub marks. I now watch the turning cylinders pretty close and try not to go to full lock. I do not mow with mine so I probably do a lot less turning than you. I bet you won't have any more issues with this heim joint. A rubber stop sounds like a great idea!
Duane
Maybe my shock is caused by the fact that I have a spinner knob on my steering wheel. I have found it invaluable, especially when using the loader joystick, and also while mowing. I decided very early-on that two-handed turning would't work while either joysticking or hanging on while mowing. Anyway, I may be hitting the limits a little hard turning quickly around a tree or other obstacle. I'll try to be a little easier with it but I won't give up the knob.
/ Disaster down below #33
<font color="blue"> so we soucl check it out on our machines? </font>
soucl...??? what the heck! /forums/images/graemlins/tongue.gif
Should have been <font color="red"> could </font> , could have edited it, but what would be the fun in that if I can't laugh at myself? /forums/images/graemlins/laugh.gif
/ Disaster down below #34
I've got a spinner knob, too. I suppose I could whack it hard in lock to lock turning, but I rarely do that.
Oh, one more thing... the PT425, while very stable, can tip over on flat ground if you are going flat out as fast and you can and give the spinner knob a crank to full lock and never let off the go pedal while mowing... at least it goes up on two wheels till you grab the joystick out of float and use the mower deck as side wheelie bars /forums/images/graemlins/blush.gif I was giving it a performance test at the little league last week and kept pushing the envelope, so to speak. Won't do that again /forums/images/graemlins/shocked.gif
/ Disaster down below #35
<font color="red"> ... at least it goes up on two wheels till you grab the joystick out of float and use the mower deck as side wheelie bars </font>
Wait'll Bubenberg hears about that! /forums/images/graemlins/grin.gif
/ Disaster down below #36
I think someone is jockeying for the test pilot position
/ Disaster down below #37
how do i aPPLY?
/ Disaster down below #38
Don't you mean Re-apply? /forums/images/graemlins/smirk.gif
/ Disaster down below #39
kids must play /forums/images/graemlins/smirk.gif MR it has been so long since i ran a pt i almost forgot,i see who i should not ask how it should be run /forums/images/graemlins/grin.gif you must have a snoopy hat and a scarf when you run it /forums/images/graemlins/laugh.gif
/ Disaster down below #40
<font color="blue">you must have a snoopy hat and a scarf when you run it </font>
he he! I've been known to rocket test mototcycles and cars, but never thought I could get such a thrill at 7 or 8 MPH! /forums/images/graemlins/shocked.gif
SHORTWOOD 5 BOLTSTER LOG TRAILER (A64276)
SHORTWOOD 5...
2003 Freightliner FS65 Thomas School Bus (A64194)
2003 Freightliner...
2017 Ford Escape SUV (A64557)
2017 Ford Escape...
2015 SolarTech Silent Messenger Towable Solar Message Board (A64553)
2015 SolarTech...
2016 Ford Fusion Sedan (A64557)
2016 Ford Fusion...
Tropic Trailer 18ft T/A Flatbed Equipment Trailer (A64553)
Tropic Trailer...
