Digging Out Cedar Tree Roots: Stump Bucket, Tooth Bar or Backhoe?
   / Digging Out Cedar Tree Roots: Stump Bucket, Tooth Bar or Backhoe? #11
I've removed birch, cotton wood, and black spruce this year. My machine (JD3520) simply isn't big enough to push over much more than 3-4" tree. I built a ripper tooth onto my ballast box that will go down about 8". I cut around the trees to break the roots. Then I either try pulling them over using a tow strap (carefully considering where the tree will go), or I use the bucket to roll up the root mat and up end the trees. I have a grapple on order because I think that will be much better than a bucket. This process is not fast. But, I'm doing this an after work project. If I were wanting to get it done, I'd hire someone with a substantially larger machine and be done with it.
   / Digging Out Cedar Tree Roots: Stump Bucket, Tooth Bar or Backhoe? #12
I have done exactly what you are trying to do. As a matter of fact - you have seen the results.
1. We used a compact track loader to work around the base and push them over. Takeuchi TL150 with a tooth bucket. We cleared a WHOLE bunch that way. You end up with a big pile of trees and a lot of stump holes.
2. We used a track hoe. We were digging a tank - and a track hoe will clear them without a problem.
3. Dozer - push them over - stump holes, etc.
4. 180hp Fecon mulcher - can turn a fully mature cedar tree into toothpicks in 30 secs. Nothing to burn - but you have stumps. Depending on how deep the mulch is - the stumps might be very tall or you might never see them.
Cedar stumps are much easier to remove when it is dry. I have gotten so when I can tell they are loose - I cut the roots on both sides and knock the whole thing out whole.
I am currently removing stumps with a Kubota SVL75 with a stump grinder. The mulch is low enough I am tried of tearing equipment up.
I am also clearing mesquites out at my other place. A tree shear on the front of a compact track loader - a guy on a grapple can't keep up. One can clear a whole bunch and if you get good with it - the stumps will be at ground level or lower.
How many trees are you talking. 100 or 200? A CTL with a shear on it you could knock that out in a week. Now the problem is piling them. You really might need two machines. One shearing and one piling. When those cedars burn - they burn hot.
That 180HP Fecon mulcher - we clear around 50 acres in a week. Nothing to burn - gone. Now I am messing with stumps. Either way you end up with stumps.
Do you want to plow the whole place? Get a dozer and push them all over. Shove them out of the way and get it done. Pile it up.
If you dont want stump holes but are OK with some short stumps here and there - rent a CTL with a tree shear. I cleared 30 acres of mesquites in two weekends.
I know renting gear sucks and we all want to own our stuff. For less than what adding a backhoe on a tractor (way less) you can have dozer delivered for a week or a month. Push all that crap and be done with it. Then you can fool with cleaning it up, burning, etc. Make a donation to your local fire department and have them come help burn.
D.
I agree with Darin on this, use the right equipment and get it done. I would not buy the equipment rather have it done. Buy the equipment you need for the long term use afterwards.
   / Digging Out Cedar Tree Roots: Stump Bucket, Tooth Bar or Backhoe? #13
If you will have a use for a back hoe afterwards, I would go with that option(see below statement). I find mine useful on an almost daily basis and cant believe how I got by without it. However if you cant justify the $7-8K needed to purchase, I would recommend renting or hiring an excavator to dig them up. An excavator with a thumb can dig them up and then pick up and pile them somewhat so he can continue to work on digging. You will have much less root ball dirt on them that way also rather than just pushing them over.
One reason I like to own my equipment is because it is there when I need it. I can work 2 hours a day or 10 and it doesn't increase my cost any other than diesel fuel. For me, my TLB stays a TLB so I don't have to hook up and unhook the back hoe because I have 2 tractors.
I would suggest that for just a few dollars more than the cost of a back hoe for your 40-50HP tractor, you can buy a full sized commercial grade backhoe to uproot all your trees, fill in the holes etc and then sell it afterward for what you gave for it OR keep it for later use if you have any. My house building contractor got a pretty nice one for $8500. It has a little slop in the pins from wear but is still very good with no leaks. They can be found and because there are so many for sale with not many buyers, they are reasonable priced.
I bought my B26 because of the small size which I needed to be able to use it in tight spaces. MY P7010 is pretty awkward in tight spots. Now I find myself going to the B26 all the time rather than the 70HP even though the LS has a cab and AC.
   / Digging Out Cedar Tree Roots: Stump Bucket, Tooth Bar or Backhoe? #14
I agree on the 2 hours here and there thing.
D.
   / Digging Out Cedar Tree Roots: Stump Bucket, Tooth Bar or Backhoe? #15
I think I would get a subsoiler. Not a TSC one but a real heavy duty one. I've heard good things about the "Fred Cain" one. With a 40 to 50 hp tractor you should be able to rip up the roots. On the larger trees you may have to get further away from the stump to where the root diameter is a little smaller but I think it would work. Dozers do this all the time. They make attachments for the front to remove wide areas of dirt and single rippers for the rear to really pull hard.
Darin, I have indeed seen the results of your work. Your place looks great! And that's what I want to do - clear it but leave some trees here and there to give it a little character and provide some shade for the livestock.
Gary, I went and looked at a couple of small backhoes today. Unfortunately, one was 3 point hitch mounted (which I'd rather avoid). The other one had a Woods frame-mounted backhoe, but was overpriced. And I saw a very nice, gently used Kubota M59 with the 3rd function on the loader and the hydraulic thumb on the BH. If only I was made of money, that beast would make short work of those cedars.
And I fully agree on owning vs. renting. I travel a lot and often have unexpected trips come up. It would suck to rent something and then have to leave town for a week. I want to be able work on my property when I have the time. It would be nice to own the equipment so it's there when I need it.
   / Digging Out Cedar Tree Roots: Stump Bucket, Tooth Bar or Backhoe? #17
If I have to rent something I like the weekend rentals. They usually cut a deal on weekend rates.
These tractors aren't made to be dozers. Maybe you just need to get a tractor with a hoe and knock it out little by little.
Have you looked for used hoes? Machinefinder usually has some.
D.
   / Digging Out Cedar Tree Roots: Stump Bucket, Tooth Bar or Backhoe? #18
I would try that first myself, those Fred Cain models are great.
   / Digging Out Cedar Tree Roots: Stump Bucket, Tooth Bar or Backhoe? #19
If you don't mind leaving stumps in the ground - cut the trunk way down low with a chainsaw. Then you should be able to push them over. Grapple them up and burn them. I have to say - this drier weather and 4-5 years for the stumps to dry out - they are coming out pretty easy. Just takes time.
Have you consider getting a compact tract loader? You can get a zillion different attachments.
Get a used one. You wont put too many hours on it anyway. Sell it for what you paid for it or more when you are done with the tree project. Then get the right tractor.
D.
   / Digging Out Cedar Tree Roots: Stump Bucket, Tooth Bar or Backhoe? #20
Boy if you could swing the M59 that sure would be a nice machine for your uses, especially with that heavier duty laoder, the 3rd function, and throw a thumb on the backhoe and you could do some serious damage.
20FT X 30FT STEEL CARPORT (A58214)
20FT X 30FT STEEL...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2018 Toro Sand Pro 5040 Bunker Rake (A59228)
2018 Toro Sand Pro...
2017 Kubota M7-151 Premium MFWD Tractor (A56438)
2017 Kubota M7-151...
2015 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 389...
1991 John Deere 4755 Tractor (A59814)
1991 John Deere...
