Buying Advice Diesel smog emission stuff?
   / Diesel smog emission stuff?
DPF equipped tractors produce only ~ 1% of the cancer and smog producing diesel particulates which are produces by ~ 25-horsepower diesel tractors without DPFs.
Turbocharging an L2501 so it produces 200 times as much pollution as a 33-39 horsepower, DPF equipped Kubota tractor should be a crime.
If you need > 25-horsepower buy a DPF equipped, legal machine.
Well, honestly, never played with a turbo on a diesel engine before. But I have a 2002 Corvette with twin turbos, and I certainly played around a LOT with tuning them in a gas engine environment. I fail to see how they could increase any emissions above what is normal. You still have to make sure the air/fuel mixture is correct across the rpm and load band they operate within. Which means you are in a plus air pressure (boost) instead of a vacuum that normally is seen by the intake of an engine. Running too rich or too lean is STILL too rich or too lean, regardless of whether you are in boost or in vacuum, which is not good for the engine.
That exhaust simply powers the impellers on one side of a shaft that drive the other side impellers that force outside cooler air into the intake. An engine is going to develop exhaust gases with or without the turbo in place. It is a very simple process, and I am surprised more vehicles don't use it.
@Rich_Z if you've not checked Mike's thread on turbocharging his L2501, you ought to. The ability to modify the tractor to produce more power, after the warranty expires, does exist. Now that's not necessarily something that appeals to you, but it may be something to consider.
I certainly keep the possibility in the back of my mind.
Well, that does sound like a good idea, except that the closest Kioti dealer to me that will likely get my business offers a free lifetime drivetrain warranty. Which I am sure putting a turbo into the mix would be the end of that warranty coverage.
The Kioti CK line has a;
2620 with a 3 cylinder 24.5 Hp 100.5 cu.in. engine
3520 with a 3 cylinder 34.9 Hp 111.4 cu. in. engine
4020 with a 3 cylinder 39.6 Hp 111.4 cu. in. engine
All three models use the same loader and if wanted the same little backhoe,
they all use the same size tires and have the same choices of tires.
Yes, that is what I am seeing too. My goal for now is to try to get a price on each of those HP variants so I can see just what those small increases in horsepower would cost me.
   / Diesel smog emission stuff? #44
Nearly 50 percent and over 50 percent isn’t a “small” increase. The practical difference is even more. The power lost to moving the tractor remains the same. You’re loosing a big part of the 25 hp just to move especially up hill. Adding another 10 or 15 hp to do usable work is a big difference. I used to operate a CK25 some. It wasn’t a bad tractor but it was pitifully underpowered. I have a Kubota L3800 now and the added HP makes a drastic difference.
I guess it is a matter of perspective and mine is colored by my days playing around with high performance engines. 10 to 15 horsepower was considered negligible, and even just enough within a margin of error to be considered insignificant. To put an addon on an engine that only gave you 15 more horsepower (if you could even reliably detect it) would be OK if it were a $100 intake or exhaust tweak. But if that same increase cost you $2,000+, well, that would be a real tough sell to anyone.
Percentages are like statistics, I guess. They can sound good or bad depending on the eyeglasses you look at them through.
   / Diesel smog emission stuff? #46
If you turned a 400 hp engine into a 750 hp engine you would be extremely impressed. 15 more hp when you only had 25 to start with is a lot.
Probably so. But then again, buying a "smart car" and getting an optional "performance increase" of only 15 more horsepower, well, not so much. :)
   / Diesel smog emission stuff? #48
The difference between a capability of a 25 vs 40 hp diesel tractor is huge. It makes a big difference in the size of pto implements it can operate and the ability to operate ground engaging implements.
   / Diesel smog emission stuff? #49
My baseline was higher, I opted for a 55HP turbo vs a 48HP NA. The gain on PTO HP gives me more options to safely run some PTO driven implements (mowers, tillers, chippers).
To me this biggest risk going from 25HP to 30-40 is just a math thing. More moving parts means more potential points of failure. The gain, imho, is much greater than the risk.
   / Diesel smog emission stuff? #50
When I first started thinking about buying my first tractor, my thoughts were to limit my search to all tractors with less than 25 or 26 (number varies, it seems) horsepower in order to avoid buying a new tractor with government dictated smog emission controls to have to deal with. Some people claim that they can be a real pain. Others are saying they are no big deal. So, what is the TRUTH?
Are some brands better than others in this department? I have been focused on probably buying a Kioti brand tractor, particularly the CK20SE CAB series, in which it appears all the models are pretty much identical except for the amount of horsepower the engine will put out. I guess it is a matter mostly of tuning and air/fuel control of that diesel engine making the difference. So I can choose to buy the 24.5 horsepower version, or perhaps the two other models with higher engine ratings (34.9 and 39.6 hp respectively), but having the onerous smog emission complexities attached.
Is this a big deal, or not? Headache, or not? Is it really something I should allow to influence my decision about what to buy?
Of course, another perspective of looking at this is: Will the difference of just 10.4 and 15.1 horsepower even worth fretting over and just buy the 24.5 horsepower version and be done with it?
New Holland Workmaster 50, 60, 70 hp (same motor just more fuel) has automatic emission that takes care of itself. You never know when it occurs and you don't have to do anything. I am sure they must have smaller tractors that do the same.
2025 AGT MH12RX Mini-Excavator with Pilot Controls & Dozer Blade (New/Unused) (A59225)
2025 AGT MH12RX...
2021 SANY SY365C9C5K (A58214)
2021 SANY...
PENDING SELLER CONFIRMATIONS (A58018)
PENDING SELLER...
2014 FREIGHTLINER CASCADIA (A58214)
2014 FREIGHTLINER...
2000 FORD F-350 SUPER DUTY (A58214)
2000 FORD F-350...
2014 Sakai SV540T Pad Roller, Chassis# 3SV53-10137, PMC Power Motive, Cummins Turbo Diesel Engine, (A59076)
2014 Sakai SV540T...
