LouNY
Super Star Member
- Joined
- Jul 4, 2015
- Messages
- 14,184
- Location
- Greenwich, NY
- Tractor
- Branson 8050, IH 574, Oliver 1550 Diesel Utility (traded in on Branson) NH 8160. Kioti CK2620SECH
Well I run the gamet of tractors here on my place,
my old IH 574 of about 60-65 Hp and an old 4 speed manual with high low and reverse ranges,
then the Branson 8050 with almost 80 Hp on the engine and a 4 speed trans with 3 ranges with a power shuttle so 12 speeds forward or reverse,
then the NH 8160 with about 100Hp and a 3 range 6 speed power shift with a reverser lever,
then I just bought a little Kioti CK2620SE hydo cab so 25 engine Hp.
One reason for the 2620 was the ability to turn the fuel up and supposedly gain 10 Hp which is a considerable difference if needed.
The Kioti CK line has a;
2620 with a 3 cylinder 24.5 Hp 100.5 cu.in. engine
3520 with a 3 cylinder 34.9 Hp 111.4 cu. in. engine
4020 with a 3 cylinder 39.6 Hp 111.4 cu. in. engine
All three models use the same loader and if wanted the same little backhoe,
they all use the same size tires and have the same choices of tires.
