adeymary
This post is old, Why do so many people still care?
Reading it also helps me learn more things
Again, quite similar to modern diesel pickups.I can’t speak for everyone. It those that operate the new machines like the manufacturer calls for have few if any issues. Those that do 2 minute tasks and idle it a lot do. I use my tractor every day and it has never had a problem with the dpf. I don’t idle it unless I need to get off for a few seconds and get back on I am approaching 700 hours on 5 burns
Sure are. Next lawnmower you buy will have a Cat in the muffler too. Chainsaws are already there I might add. Stihl is circumventing it with their E-Tronic system but eventually they will also succumb.Personally I hate the DEF fluid the DPF filters but they are probably here to stay
gee, I'm over 6000 hours on one and 4000 hours on the other and NO burns...lolI can’t speak for everyone. It those that operate the new machines like the manufacturer calls for have few if any issues. Those that do 2 minute tasks and idle it a lot do. I use my tractor every day and it has never had a problem with the dpf. I don’t idle it unless I need to get off for a few seconds and get back on I am approaching 700 hours on 5 burns
The difference in 25 hp and 35 hp is significant. The 25 hp model is going to be critically underpowered. They wouldn’t even offer that option if it wasn’t for the emission standards.One reason I am heavily considering the Kioti CK20SE series with the cab is because all three models weigh the same, and have nearly all the same dimensions. 3,397 lbs. And they are not so wide that any one of them would give me headaches trying to get between the trees on my property. 54.53 inches.
So I need to find out prices to see how much the higher horsepower models will cost and figure if one of those would be worthwhile for the modest HP gains even with this emission stuff involved.
I can tell you from experience with my L2501 HST, going from 25 HP stock, to 44.1 HP with the Turbo Kit, was a significant improvement in operating performance. Luckily, no regen or DPF for me.
Mike
@Rich_Z if you've not checked Mike's thread on turbocharging his L2501, you ought to. The ability to modify the tractor to produce more power, after the warranty expires, does exist. Now that's not necessarily something that appeals to you, but it may be something to consider.
I certainly keep the possibility in the back of my mind.
How’s that? Did you turbo a L2501 then do emissions testing? A properly tuned turbocharged diesel burns pretty clean.DPF equipped tractors produce only ~ 1% of the cancer and smog producing diesel particulates which are produces by ~ 25-horsepower diesel tractors without DPFs.
Turbocharging an L2501 so it produces 200 times as much pollution as a 33-39 horsepower, DPF equipped Kubota tractor should be a crime.
If you need > 25-horsepower buy a DPF equipped, legal machine.
That's not what they said on The View.How’s that? Did you turbo a L2501 then do emissions testing? A properly tuned turbocharged diesel burns pretty clean.
Until it gets lugging in the lower end of it's power band...A properly tuned turbocharged diesel burns pretty clean.
It still will not be any worse than the tractors you own. Should it be a crime to run your machines?Until it gets lugging in the lower end of it's power band...
How so? Both are well maintained and properly tuned are rarely produce visible particulates unless really lugged, something I try not to do They are totally compliant T3 final tractors, right down to the 'puff' limiters.It still will not be any worse than the tractors you own. Should it be a crime to run your machines?
Because a turbocharged diesel is much more efficient and has smaller carbon footprint than a naturally aspirated engine. I am a fan of your tractors and have no issues with them but saying adding a turbo should be a crime because of increased smog is not only ridiculous but also completely false.How so? Both are well maintained and properly tuned are rarely produce visible particulates unless really lugged, something I try not to do They are totally compliant T3 final tractors, right down to the 'puff' limiters.
All I see is heat from the exhaust stack when working them and they both get excellent per hour fuel consumption and I plan on running them until I don't require them anymore plus both will command a high resale value because people don't want the emissions stuff if they can avoid it.
Just had the M9 cab tractor professionally appraise and it appraised for more than I paid for it new and the other one appraised for 20 grand more than I paid for it 3 years ago.
I never said that, that it increases smog or visible particulates in the case of a diesel. IMO, the biggest plus of mine is the engine longevity. The VTE engine is probably the most reliable engine Kubota ever built, they will run in the excess of 30K hours with very minimal care other than proper oil changes and filters. They are the 4020 Deere in Orange clothing.I am a fan of your tractors and have no issues with them but saying adding a turbo should be a crime because of increased smog
That’s precisely the opposite of what has been observed when testing my Turbocharged L2501. Startup aside, using modern diesel emissions testing equipment at our dealership, the Turbocharged L2501 is running marginally cleaner when testing for particulates. Now, that said, we weren’t using the same instruments that the EPA uses and we didn’t have a baseline test on my tractor. We tested a completely stock L2501 from a close by business to compare.DPF equipped tractors produce only ~ 1% of the cancer and smog producing diesel particulates which are produces by ~ 25-horsepower diesel tractors without DPFs.
Once again, start up aside, this has not been my experience with the Turbocharged L2501. Because we’re using a properly sized Turbo for the application, we’re getting boost just off idle making the engine extremely efficient.Until it gets lugging in the lower end of it's power band...
