Diesel Programmer's
/ Diesel Programmer's #31
Have any of you long wheelbase Cummins owners swapped your 2pc driveshaft for a single one?
I ordered one for my MegaCab and plan to pick it up at the dealership tomorrow. I've read that it makes the trucks a lot smoother.
Travis
Travis
I have never even looked until you said something. For a dually mine rides pretty nice thou,sometimes forget even in a 1ton.
/ Diesel Programmer's #33
Yours could already be a 1 piece. They used both one piece and 2 piece, often on the exact same model trucks. The 2 piece has a carrier bearing that is known to wear and cause vibration.
Mine's an 06. The dealership couldn't recommend a 1pc part# for my truck, but I found it by researching the forums. There's hours of reading on that topic.
Travis
/ Diesel Programmer's #34
Mine is a shortbed and it has a nasty vibration at somewhere around 65 to 75 mph. Faster or slower it goes away. I've also done some reading on the forums and its seems its usually the driveshaft, but not always. It can be very hard to fix.
/ Diesel Programmer's #35
Have any of you long wheelbase Cummins owners swapped your 2pc driveshaft for a single one? I ordered one for my MegaCab and plan to pick it up at the dealership tomorrow. I've read that it makes the trucks a lot smoother. Travis
My 07 LWB has the two piece shaft while my dads 08 LWB has a aluminum one piece. I have two buddies that swapped from the 2 piece to a aluminum one piece and both said the truck was smoother after. When I need to start replacing u-joints in mine I'll probably just order a one piece.
/ Diesel Programmer's #36
Yours could already be a 1 piece. They used both one piece and 2 piece, often on the exact same model trucks. The 2 piece has a carrier bearing that is known to wear and cause vibration. Mine's an 06. The dealership couldn't recommend a 1pc part# for my truck, but I found it by researching the forums. There's hours of reading on that topic. Travis
The only truck I have ever owned with a 2 piece drive shaft was my 05 Dmax. It ate carrier bearings and U-joints also.
Never thought of swapping in a one piece.
Chris
I looked under mine and it's a 2 piece. So I desided finally on these
RaceMe pro with touch screen,that will be able to monitor boost,EGTs,ETC and can change levels on the fly
MBRP cat-back 4"exhaust with muffler
DPF and EGR deletes
/ Diesel Programmer's #38
Hmmm. Shortbed would be a 1pc anyway.
I don't have any nasty vibrations, but it shudders a little at takeoff and has some annoying bouncy vibes on the interstate. I do have a 4.5" suspension lift and 35s though.
I'm planning to change mine out today before I go home, so i'll let you know what happens.
I guess you gotta take the bad with the good when you drive a real truck with straight axles. :laughing:
Travis
/ Diesel Programmer's #39
I ran an Edge in my 03 Powerstroke for the 10 years I owned it. Kept it on race program. 80 HP increase. No problem since I opened up the intake, exhaust, and put in gauges.
/ Diesel Programmer's #40
DPF and EGR deletes
Nice. You're definitely gonna have a smile on your face!! :thumbsup:
Travis
2016 Dodge Charger Sedan (A59231)
2016 Dodge Charger...
2020 MACK GRANITE (A58214)
2020 MACK GRANITE...
1998 CHEVEROLET 1500 LONG BED PICKUP TRUCK (A59905)
1998 CHEVEROLET...
20' SINGLE AXLE INDUSTRIAL TRAILER (A59823)
20' SINGLE AXLE...
(12) SKLP SK-LJB-12 Polyethylene Roadbed Protection Pads (A60463)
(12) SKLP...
Harlo HP6500 (A60462)
